I am using a 3900x at stock settings and using the cooler it came with, with PBO set to auto.  While I haven't had any issues with temps or fan noise. (Motherboard is X370 Taichi)
What I wanted to ask if there was any other 3900x users that overclocked their CPU on the stock cooler or even after market, and if so what speed you settled for, or is it not even worth overclocking?
Last does anybody know if the ability to use 4 memory sticks at rated speed been fixed?  I currently have 32 GB of Corsair 3000mhz(2x16) and had thought about bumping it up to 64 GB while memory was somewhat still cheap.
Thanks
Edited by Mayorville
https://linustechtips.com/topic/1098770-3900x-stock-vs-overclock-cooling-and-memory/
That motherboard features T topology, enabling it to handle 4 memory dimms at rated speeds better. You should be able to have 64GB at 3000MHz.
Primary PC:
unless you are going the full mile of overclocking the entire chip, then its not worth it.
the memmory controller is much better than it was, but dont go expecting 4 high capacity dimms to run at rated speed. tho it will probably work fine.
I'm running my 3900X at 4400Mhz all cores at 1.3375v, via manual OC in Ryzen Master under Profile 2, my RAM is set at 3200Mhz as well. Idle temp's 34C....'ish. I'm using a Thermaltake Water 3.0 360 AIO ina CoolerMaster H500M case, pretty happy with what I see, though I can't net great framerate at higher res (3440x1440) since I'm using a PowerOlor RX VEGA64 Red Devil and not an RTX 2080 Ti. I'm waiting for big NAVI 23.......next year
Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Lexar NM790 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 23H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS)2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 23H2
