What do you guys thinks? Both cpus doesn't seem like it's worth it to overclock at all and just stick with stock.
                                     "Linux is only free if your time has no value." ~Jamie Zawinski
"Peaches" CPU 10900k // Heatsink Liquid Freezer II 280 // GPU EVGA 2080 Super XC // MB z490 Vision D // RAM Corsair Vengeance 80GB 3600 // PSU Corsair RMx 850 // OS 2x Intel 660p 2TB NVMe // Monitor Half 8k // VR Vive Index // Mouse Naga 2020 // Keyboard Ducky Shine 7 // Fedora plus i3wm
"HTPC" CPU 3900x // Heatsink D15 // GPU GTX 980 // MB Tuf x570 Plus // RAM Corsair Vengeance 16GB 3600 // PSU Corsair RMx 850 // OS Kingston NV1 500GB NVMe // Monitor 4k // VR OG HTC Vive // Fedora plus i3wm / Windows 10
"Dell Powerbottom N690 1U Blade, Totally Not a Shitty Desktop" CPU 2700k // Heatsink Stock // GPU EVGA GTX 970 // MB Yes // RAM Vengeance 16GB DDR3 // Monitor xrdp // VR Google Cardboard // OS Kingston 480GB // Not Porn 4TB Spinner // Fedora
"SalmonLeaves" RPi4 Model B 4GB DNS/NAS // RPi 2 Model B 1GB
https://linustechtips.com/topic/1098721-3900x-9900k-not-worth-overclocking/
9900k is definitely worth overclocking. the 3900x could be squeezed more with BCLK and PBO, but I'd say it's not nearly as noticeable as memory overclocking.
Desktop benching:
the 9900K overclocks farther, but its single threaded performance at stock is enough for 144Hz gaming and the like, so not there's not really a reason. same story with the 3900X. Down the line, when performance is lacking, an overclock does indeed assist performance.
Primary PC:
The 9900k would benefit more from OCing, but tbh with the power consumption of the intel part at stock I'd not bother overclocking unless it really is needed.
On a side note, if you are interested in putting your chip to work for the betterment of man kind and potentially wining some prizes then why not consider signing up to the LTT Official folding month. You need to actually participate in order to be entered for the prize draw.
My Folding Stats - Join the fight against COVID-19 with FOLDING! - If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
  • CPU
    Ryzen 9 5950X
  • Motherboard
    Gigabyte Aorus B550 Elite V2
  • RAM
    32GB DDR4 @ 3400
  • GPU
    Inno3D RTX 4070 Ti + Dell RTX 2070
  • Case
    Cooler Master - MasterCase H500P
  • Storage
    WD black 2TB NVMe SSD, Seagate BarraCuda 1TB x2, Crucial 1TB SATA SSD
  • PSU
    Corsair 850e
  • Display(s)
    Lenovo L29w-30 29 Inch UltraWide, 4x Dell P2417H(portrait)
  • Cooling
    Arctic Liquid Freezer II 360
  • Laptop
    Lenovo Legion Y540
  • Phone
    Sony Xperia 5, Sony Xperia 5 IV
The current dichotomy is that you can get some sweet performance gains with intel with overclocking, given you have some good cooling.  And you will need the cooling.  You get a more noticeable gain than ryzen will get.  And you will get better clocks and the benefits that go with that.
Ryzen doesn't overclock much, and the gains you get from it are really kinda, meh at best.  All that said...out of the box it comes performing almost tip-top, and can really do great with the stock coolers they come with.  Can you get a couple 100 mhz more with a 150$ AIO?  Ya sure, but it's a huge waste of money.  Ryzen comes screaming out of the box with great performance that matches (or beats) intel so there is something to said about that ease of use.
El Zoido:  9900k + RTX 4090 / 32 gb 3600mHz RAM / z390 Aorus Master
The Box:  3900x + RTX 3080 /  32 gb 3000mHz RAM / B550 MSI mortar
9900k gets so hot though while ocing and I don't feel comfortable with that as I will be using an all-in-one.
I like the 9900k's boost a lot and hope I won't be asking too much out of the 3900x or 9900k while running virtualization plus vr gaming.
 I was hoping to oc it for vmware guest os? and vr gaming, but it just doesn't seem like it's worth it. They aren't sandy bridges. Sigh. That's actually something I haven't done before, but always meant to. Fold.
I don't know if it's worth turning off the single or two core boosting though for an all core oc on 9900k.
I was looking at getting a 3900x for those beautiful, sexy cores and threads for 24/7 virtualization, I'm going to use my linux guest os as my main driver and then just alt tab into windows for gaming, but the 9900k has some pretty good benchmarks for the gaming side. I'm so conflicted. 12 cores / 24 threads vs 8 cores / 16 threads.
Well now is the perfect time to get on board!
  • CPU
    Ryzen 9 5950X
  • Motherboard
  • RAM
    32GB DDR4 @ 3400
  • GPU
  • Case
  • Storage
  • PSU
    Corsair 850e
  • Display(s)
  • Cooling
  • Laptop
    Lenovo Legion Y540
  • Phone
It looks like I will have an extra computer soon. Ha!
Out of the box, my 3900X is screaming fast, that's for sure. But, what concerns me is the voltage, it is at 1.475v......though idle temp's at 36C'ish, so it isn't bad (using Thermaltake Water 3.0 360 AIO). I'd read that it isn't good for the longevity of the CPU to have the voltage set at that level. I used Profile setting to run all cores at 4.4ghz at 1.3375v and it now idles at a cool 34C. Room temp set on my AC is 25C, so I'm happy with the temps.....and speed of my rig. Played games and ran some benchmarks with no issue....
Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Lexar NM790 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 23H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS)2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 23H2
