2080ti, Displayport monitor connected but not HDMI
So i have just installed a 2080ti, and when I plugged my monitors into it only the one using the Display port works not the ( also i can only get 60 hz on this monitor even though it supports 144) The other 2 monitors use HDMI which for some reason dotn get detected when plugged into the GPU.
Also i can only get 60 hz on the monitor using the display port even though it supports 144hz.
Any help is much appreciated. Thanks. :)
