Sooo I plugged my led fan rgb header into the rgb header. It doesn’t post, it only turns on for less then a sec then turns off,I know it’s not the GPU or the Ram or the psu, what should I do?
mb:tuf gaming b450m plus matx
cf:cm mf 120r a rgb
