Monitor Problem? Not sure the cause
Go to solution Solved by Constantin,
in those situations always check the cables, they are very sensitive.
Spray the cable and the monitor with a special contact spray (absolutely safe)!
So I have a Monitor problem I think. every so often my monitor just has a grey tv static screen after like 15 second it turns green and fixes itself. I can't get a video of what happening since the static happens at a random time and fix itself before I could grab my phone to record it. My second display is a TV screen (don't judge) but it doesn't have any issue when my primary monitor does the weird glitch. I also try using google but there no result on this type of problem and wonder if anyone might know what type of problem this is.
*This only happens with chrome. When I play games there no issue.
I turn off Hardware acceleration when available in chrome. I also try turning it on. No different
My monitor is an Asus VS247H-P  got it for like 3-4 year ago.
Graphic card is XFX Radeon RX 580 8 GB GTS Black Edition OC+ Video Card
Graphic Driver is 19.5.2
But this monitor has a Display port adapter to HDMI.
This is the example Static screen for 10 seconds then 3-second green screen after that it back to normal.
EXAMPLE:noise-on-tv-screen-bars-of-analog-tv-static-moving_rn7at3f2_thumbnail-full01.thumb.png.7c05c860f7d31fcca9a015d25061aa48.pngvideoblocks-monitor-with-green-screen-snow_rmk48whdg_thumbnail-full01.thumb.png.64d564255c522f67c183430ba48a54f9.png
https://linustechtips.com/topic/1098314-monitor-problem-not-sure-the-cause/
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
