Normally when you upgrade RAM or touch anything internally you would need to remove the external battery block first.
What about nowadays integrated batteries are inside and usually need to take off the whole bottom panel.
I've seen "disassembly/upgrade" videos on Youtube where they don't even unplug the battery when they install RAM or new SSD,
Are those integrated batteries less susceptible to frying the motherboard?
https://linustechtips.com/topic/1098021-servicing-laptops-with-integrated-battery/
Best practice is to unplug the battery before doing any servicing. But for the most part you'll be fine as long as you ground yourself and don't bridge together any connections or solder points on the board.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Can it still run without battery pack like older laptops? via just Power cable?
Sometimes I want to save the battery capacity as it's plugged in all day so could I remove integrated battery in same way?
You can, at least for the laptops I've worked with. This mainly applies to the HP EliteBook series. I would imagine the same can be done for most makes and models. The issue is that it's more hassle and its worth. My ASUS Vivobook for example has a sealed battery so I've been using their battery health utility. What it essentially does it limit the charge to around 60%.
How does the Utility work and where do I get it?? I have Asus laptop too but now the battery only lasts like 30mins-1hr.
Also that's why I asked the original question because I'm looking for new laptop maybe Dell and they don't have the removable battery blocks!
I was maybe avoiding the integrated batteries but you almost change my mind.
Mine came preinstalled but you can download it directly from their website. https://www.asus.com/us/support/FAQ/1032726/
Depending on how well your laptop still performs outside of the battery, might not be a bad idea to perhaps invest in a replacement battery.
7 hours ago, BlueChinchillaEatingDorito said:
If you know any good 3rd party battery managers plz advise.
My Vivobook is unsupported X556UV boooo! https://www.asus.com/support/FAQ/1034022/
https://www.asus.com/au/Laptops/ASUS-Vivobook-X556UV/HelpDesk_Download/
Yeah I was probably gonna replace battery down the line but definitely won't be buying another Asusbook anytime soon. Bad "support" for my current model which only few years old!
