Fps drops due to packet loss and unstable internet?
So when i play fortnite the game runs smooth on 144 fps but then there are sudden drops for a sec to like 30 fps or 14. And when i look on top near the network status the line goes up and down and sometimes red lines show. But after dat the game runs smooth and after a while again. Same for cs go the game will be running at 200+ fps but will suddenly drop to 130fps and back to 200+. I dont have this issue in destiny 2. Nor in paladins. Nor in deciet.Nor in apex legends. I personally feel its my old router.
2 hours ago, PrinceNorris said:
I had the same issue. In my case computer was connected directly to the router. After connecting it to the switch instead of direct connection, the problem stopped. I still don't know what is causing this issue but it seems like the router has some difficulties with direct connections to some of my devices. So I would recommend trying a switch if you have one.
I dont have a switch at home but which brand switch do u have?
