Unsure if they even sell those separately. Also, in that regard of airflow, from what Science Studio showed us the temp delta of the P400A white isn't really that much of an improvement either. It was seen equal to stock NZXT H500 on a negative pressure setup. Adding an exhaust improved deltas, but tbh that can be said to almost every case even the ones with good airflow already. The 220T that has the same 3-front fan config on stock and Meshify S2 on stock handily beats the P400A by a couple of degrees.
The P400A black might have better airflow due to less coatings of paint. For comparison, these are the holes of the P400A white vs the H500 Mesh from CM.
  • 5 weeks later...
Not sure of your location but they are available on the UK overclockers website for £17.99 in white or black.
They do state they are not a 100% correct fit as shown in the pictures on the following link
https://www.overclockers.co.uk/phanteks-eclipse-p400a-metal-mesh-front-panel-black-ca-09t-pt.html
  • 3 weeks later...
I have the old p400 with tempered glass side. Phanteks now sells the new p400a front panel.  Ordered and just installed the new p400a front panel and it fits perfectly. The only difference is that the fans are slightly off center to the left which I don't care about. $20 plus shipping off Phanteks USA is a good purchase if you ask me.  I'll have to do some thermal testing later. Gamers Nexus did testing and noted significantly improved thermals with the new panel.
https://www.phanteksusa.com/collections/replacement-parts/products/phanteks-eclipse-p400a-air-mesh-front-panel
