I have recently come along a thread with some concerns regarding the S12II/M12II. By simple logic I would assume that the S12G series have the same issue. Can anyone confirm it?
I bought it in Late 2014, it still has 3 months of warranty.
Also, since I'm already planning on replacing the unit, I'm considering the Seasonic Prime Ultra 550W Gold or Platinum (they have 15 bucks difference here in Hungary), do the cables of these PSUs will be sufficient length in my Phanteks Enthoo Pro TG case?
You can find my config on my profile (base is 8600K and 1660Ti).
https://linustechtips.com/topic/1097560-question-regarding-seasonic-s12g-550/
There have been no reports of problems with the S12G - it's not the same platform as the S12II and M12II - the S12G is using a non-modular X-series platform and is MUCH higher quality. I have one myself and have never had issues with it - no real need to replace it imo but your call.
Good choice!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
I have heard both good things and bad things about SeaSonic.  But you can't really trust amazon reviewers.  They are a small portion of people, and you can't trust it.  Some guy said about the SeaSonic that is died on him after 2 months.  Then he got another one and that one die within a year or so.  But this is a small portion of people.  As 5x5 notied to us they have fixed some issues with their previous line of PSUs and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
I mean, Amazon reviews are piratically the worst source of information - you can find negative reviews about everything and in a lot of cases, it's usually user error - if someone had 3 high end SS PSUs die on him, I'm willing to be he fucked up somehow.
That being said, the SeaSonic Focus platform was a flop. Hopefully they learn from that mistake.
Bitfenix Whisper M kiváló választás lenne, 28k körül megkapod az 550wattost, teljesen moduláris, csendes. Csak a szokásos magyarkodás a garanciával: a hét év gyártóiból megkapsz a bolttól hármat. Kár, hogy a Formula 550 ára felment, mikor 22k volt, nagyon slágercuccként vitték.
https://www.arukereso.hu/tapegyseg-c3158/bitfenix/
Ha nem életbevágóan fontos, hogy moduláris kábelezés legyen, simán Formula Gold 450w már jó lenne. A 1660Ti nagyon kis takarékos kártya, még egy cibált 8600k mellett sem fog kelleni hozzá 450wattól nagyobb táp.
Más márkákat nézegettél? Corsair TX550M; RMX; EVGA; SuperFlower Leadex sorozat, v hasonlók? Mennyit szánnál rá? Van kiszemelt bolt-áruház, ahonnan vásárolnád? :)
Nézd meg a PSU calculatort az aláírásomban, a BeQuiet! oldalára visz. Ott ki tudod számolni a fogyasztást, kicsit túlbecsüle. A Te konfigod még húzva is kb. 300wattot igényelne játék& terhelés során. Így 450watt bőségesen jó, és abból is a WhisperM vagy Formula Gold tökéletes lenne Számodra.
Life is really challenging. I don't always suceed: )
Köszi a választ!
40 rugó körül lenne rá.
Corsair RMX-et néztem még, Rufusznál az 1000W-ost 40 rugóért adják, igaz csak két év garival (tudom, overkill, csak gondoltam megemlítem). Boltból Alza a preferált, ott az RMX-re megadják a 10 év garit. Illetve ahogy fentebb is írtam, SS Prime Ultra Gold/Platinum (besorolás nem tudom mennyit számít anyagilag hosszútávon) 550-es, Alzánál 12 év garit adnak. A 650-es RMX is kiszemelt, 34k-ért. (550-es lenne jó, csak az nincs Alzánál).
Lényeg az, hogy mindenképp olyan tápot szeretnék, ami 'Tier A+ (Ultra High-end)' kategóriás a tápos listánál, illetve a fenti Phanteks házba kényelmesen elférjen a CPU kábel, a mostani S12G 58 centi, és eléggé neccesen fér már csak fel a helyére.
Az RM650X jó kellene, hogy legyen. A kábelhosszakat itt találod: https://images10.newegg.com/UploadFilesForNewegg/itemintelligence/Corsair/00153287_specs14453431606451448509906690.pdf
650mm hosszú a cpu kábele, de az alaplapé is 510mm. Nekem elég hosszúnak tűnnek.
Alzán meg 10 év garancia& ingyenes szállítás& akciós ár. Szerintem nem jársz vel' rosszul, de, azért várd meg a guruk tanácsát. :)
https://www.alza.hu/corsair-rm650x-2018-d5494144.htm
It is much higher quality, but it doesn't use the X series platform - it uses the G series platform.
@Vejnemojnen - talking to OP on his native language is considered rude by the internet forum etiquette, since other members cannot peer-review your recommendations, discuss them, or agree or disagree with them.
Thank you! I did not know that. I will be careful to avoid it in the future.
In a nutshell: I just recommended Bitfenix WhisperM, because, those are cheaper than SeaSonic Focus Plus Gold or Corsair RMX units, though most retailers don't provide the seven year warranty period of the manufacturer.
The OP mentioned, that probably he'll pick a Corsair RM650X. I can only support this idea, as the unit comes with 10 years warranty from Alza, and the postage is FREE. And The PSU would be suitable for the OP, as, it has very loong power cables. And the Corsair units priced well ~ 103 euros with shipping for the 650w version.
I guess that should be all. :) Sorry again. Being rude was not my intention.
