Hi all,
First things first, I am working on my 2nd rig and first water cooling loop. With that said I am still learning a lot about the PC world and was just informed about how the sales of GPUs work.
So, I am wondering if a GPU is being water cooled, should I just get the standard version or still go for a reference card? With the cooling being the same, would the reference card be still better or would it be the same performance as the standard? I am looking at the Gigabyte GeForce RTX 2080 8 GB WINDFORCE Video Card or should I just go for a Nvidia 2080 Super?
Part list below.
https://pcpartpicker.com/user/DesigningJake/saved/4bgK4D
Going to be using this rig mainly for gaming, designing and why not, streaming.
Any insight would be greatly appreciated!
Thank you,
Jake
When you say watercool I'm going to assume you mean custom. What's not so important is a reference cooler but a reference PCB. Most blocks are based off the original AMD/NVIDIA PCB layout but some manufacturers will go the extra mile to design their own custom PCB. Some waterblock manufacturers will design blocks to fit these special cards but not always so make sure it's compatible.
Once you replace the stock cooler with the block the temps will be ~ the same regardless of which you started with. It doesn't matter. Unless you had a factory overclock in which case temps may differ.
Reference = standard cooler, all others are add in board (AIB) GPUs made by the various companies
The RTX 2080 and the RTX 2080 super are two different models, it isn't just the cooler.  Think of it like a 2080 vs a 2080 ti, they will have vastly different performance and the Super is definitely going to be well, superior
Want to custom loop?  Ask me more if you are curious
Think I am getting it a little better now. Looking at that now, I should have just used the 2080 regular to compare.
So if I were to take a Nvidia 2080 and a Gigabyte 2080, then use the same custom water cooling loop on both. The preference on the Gigabyte could be better, depending on the customization they did to the PCB? Though the base still coming from Nvidia?
Ghe GPU chip is the same, and the PCB is different.  When watercooling, the difference is almost nonexistent, so you need to focus on the availability of waterblocks.  A reference card is garunteed to get a waterblock, but seem to be hellish when it comes to dismantling.  What I would do is get the cheapest GPU that also has a waterblock that you like, and buy it
So.....For general Compatibility...then the Normal nVidia reference card is best..
However...The other companies bin their memory chips to the Card level you buy...so...if you find a Third-party compatible Watercooler....then generally you will have a far better Mem OC on that compared to the nVidia stock.
Awesome, all explained. Thank you all for helping me with this. I did find a water cooling block for the Gigabyte GPU at EBWK, so most likely going with that.
Though, I can't get all the parts for another 3 weeks, will see if anything drops in price or something new come out lol.
Thank you again for your help.
