20+ hours of continuous rendering (Cinema4D) on Ryzen 2700X (are constant high temps harmful?)
Solved by ashinu77,
Thank you so much everybody. It really helps. I'm a bit calm now haha, since I didn't wanna be under that constant worry that my new CPU is being killed everyday. But as a few of you mentioned, down the line over the next couple of months or so I might invest in a better CPU cooler like the BeQuiet Dark Rock series or one of the triple fan liquid cooling ones (Jayztwocents once showed that single and dual fan radiators sometimes don't make much of a difference if we're really going down the liquid cooling route).
Thank you once again to everybody who responded! I really appreciate it
PS: if you're curious what the render was all about, I've attached a video. That's the final result of it all
