Blueshift's memory module to be 1000 times faster than conventional memory
Go to solution Solved by Meandme,
Background:
https://www.techopedia.com/definition/14630/von-neumann-bottleneck
Trends:
http://blog.appliedmaterials.com/tackling-big-questions-memory
With usage of faster memory you could integrate more cores into CPUs/GPUs.
Blueshift Memory has been created to boost special Big Data problems.
Some O(n) problems are running on O(logn) or even O(c).
Test videos from last year:
theiet.org/new-form-of-computer-memory-is-1-000-times-faster/
According to this article, this new startup called "blueshift memory" have developed a new kind of memory module which could be upto 1000 times faster than the ones we use today.
They give analogy with a city where everything - shops, houses, etc. are constantly changing. This refers to data being moved around in a conventional memory module.
There memory module, using the same analogy , in some ways gives each place a sort of permanent address.
The thing that is mind boggling is how can fixing placement of data in RAM speed up memory?
At best it can improve processor's cache performance due to spatial locality of data.
I am not able to think anything beyond.
There is nothing given about the internal workings of the memory.
I want to know what's happening inside; even a discussion on rough possibilities will do.
It feels like showing a bone to a dog, but then never really giving it to him.
Their website - https://www.blueshiftmemory.com/
We've heard so many promises from startups coming forth with such allegedly revolutionary products that I am expecting us to be able to build lightsabers in next few years.
Seriously, if it sounds too good to be true it probably is.
The ability to google properly is a skill of its own.
Yeeeaa I dunno but this sounds a bit weird to me.
right now RAM is fast enough, especially for servers.
If we do run into limitations it is usually that the RAM is just too far away from the CPU (basically the trace lay-out limits speed)
And 1000 times faster, compared to what and what exactly is faster? Are they talking about latency or just raw speed?
There is no point in insane fast memory if it takes like a second to respond or memory with very low latency but is slow as balls.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
Cool but is it compatible with mainstream processors?
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
1000x faster than EDO?
"We also blind small animals with cosmetics.
We do not sell cosmetics. We just blind animals."
"Please don't mistake us for Equifax. Those fuckers are evil"
This PSA brought to you by Equifacks.
PMSL
Ram is a major bottleneck and the gap is growing bigger, not smaller, since we started getting more cores but not faster ram. Look at server systems, you have 6 or 8 ram channels per socket. Tricks like large L3 caches are only a workaround until we get fast enough ram to keep up with the cores.
Main system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, Corsair Vengeance Pro 3200 3x 16GB 2R, RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
for some reason I read the companys name as bull$h!t.
So Will ddr4 be cheap now?
I live in misery USA. my timezone is central daylight time which is either UTC -5 or -4 because the government hates everyone.
into trains? here's the model railroad thread!
Back in the mid to late 90's I read a really, really exciting article about how CPU's would soon be built using crystals and light to process data.
That was around 96-97.... it's 2019... Where are my crystal CPU's dammit.
System 1: Gigabyte Aorus B450 Pro, Ryzen 5 2600X, 32GB Corsair Vengeance 3200mhz, Sapphire 5700XT, 250GB NVME WD Black, 2x Crucial MX5001TB, 2x Seagate 3TB, H115i AIO, Sharkoon BW9000 case with corsair ML fans, EVGA G2 Gold 650W Modular PSU, liteon bluray/dvd/rw.. NO RGB aside from MB and AIO pump. Triple 27" Monitor setup (1x 144hz, 2x 75hz, all freesync/freesync 2)
System 2: Asus M5 MB, AMD FX8350, 16GB DDR3, Sapphire RX580, 30TB of storage, 250GB SSD, Silverstone HTPC chassis, Corsair 550W Modular PSU, Noctua cooler, liteon bluray/dvd/rw, 4K HDR display (Samsung TV)
System 3 & 4: nVidia shield TV (2017 & 2019) Pro with extra 128GB samsung flash drives.
Yeah this is either major overhype or major bull.
Like you said lots of ram channels. If that wasn't working adequately in most cases we would have seen more substantial changes.
Where entirely capable of building higher bandwidth interconnects, but doing so would mean new tech and thats costly enough it's not a serious proposition.
Hmmmm
it better not cause a resonance cascade while going so fast
I totally agree with that. And my database servers that take advantage of RAM tables are with me on this.
Tbh that is not the fault of ram but of the CPU's not supporting fast ram (and for that reason no fast ram with ECC exists). We have ram that can easily do 3000+Mhz, even the 4000Mhz barrier can be smashed by some ram kits, but that's way out of spec for most server cpu's.
Taking EPYC as an example, that maxes out at 2666Mhz, that is really slow compared to what we get on the desktop if we OC it. It would help a lot if server CPU's would support faster ram because it exists and it does help (zen for example performs a lot better with faster ram) but they don't sooo yea...
I'm not saying faster ram magically solves everything, but with the current tech we have it seems possible we can make some server stuff that's not as badly bottlenecked by ram as most servers are right now.
It's always very interesting to see memory and storage advances, even being far in the future. Maybe one day eventually everything being like light based storage and chips.
| Ryzen 7 7800X3D | AM5 B650 Aorus Elite AX | G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | Sapphire PULSE Radeon RX 7900 XTX | Samsung 990 PRO 1TB with heatsink | Arctic Liquid Freezer II 360 | Seasonic Focus GX-850 | Lian Li Lanccool III | Mousepad: Skypad 3.0 XL / Zowie GTF-X | Mouse: Zowie S1-C | Keyboard: Ducky One 3 TKL (Cherry MX-Speed-Silver)Beyerdynamic MMX 300 (2nd Gen) | Acer XV272U | OS: Windows 11 |
There's not a fault to be applied but merely the reality we're not in a good balance right now and it is getting worse, not better. Servers buy in quantity and they care about reliability. The fast ram kits you can get are relatively exotic, specially binned and hardly mass produced. Compatibility is also far from 100%. DDR5 will eventually help. For now we're left with trying to cram in more channels or using caches to relieve the pressure. I'm almost surprised we haven't gone back to on package L4 caches yet. A local high speed interconnect could make that very interesting.
Background:
Trends:
Yea, if they want people to take them seriously they need to show their shit works and give it to neutral parties (reviewers) to verify.
If you're going to try advertise your startup... at least do it properly
That's an F in the profile pic
