Will ryzen 3 1200 work on b450 mobo
Solved by SpookyCitrus,
9 minutes ago, ZShooter360 said:Would I have to update anything for it to work?
No, only reason you have to update a motherboard to work with a CPU that's compatible is if it's newer than the motherboard, the B450 and X470 boards have backwards compatibility with 1st gen Ryzen CPUs. If you wanted to use a Ryzen 2000 CPU with a B350 or X370 then you would have to update, same with the new Ryzen 3000 CPUs with B450 and X470.
