Search In
  • More options...
Find results that contain...
Find results in...
Any way to fix or lower the noise of the Asus strix rx 580 coil whine
I've heard that certain power supplies combined with certain graphics cards can reduce the sound of coil whine but which psu to choose? Can I also lower the clock speeds on it but not so low that it will perform way worse?
Sometimes different combination of GPU and PSU can lead to reduced coil whine. I tried 3 different PSUs and 2 different GPUs ... any combination I made, coil whine was always there.
My "solution" was, to move PC in room below mine, and simply buy 5M displayport/USB/HDMI cables. Now noise can't get to me and I can sleep peacefully.
Intel i7 9700KF 5.0GHz | EVGA Z370 Micro ATX | Dark Rock 3 | ADATA XPG Z1 3000MHz 32GB | RM650x | GTX 1080 Ti EVGA SC2 | Thermaltake Core V21
Samsung EVO 960 M.2 250GB | Samsung EVO 850 250GB | HyperX Fury 480GB | 3x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
What about changing clock speeds?
