RTX 2060 and i5 2320 does it bottleneck?
afaq0
I currently have a GTX 1050 ti with an i5 2320. They perform quite well and happily push 144fps in certain games like rocket league and CS GO for my 144hz monitor. However, I am thinking of purchasing a new GPU like a RTX 2060.
Would the CPU bottleneck the RTX 2060? If so, what CPU would you recommend to go with the RTX 2060? I think if I did go for a new CPU, I would be getting a new motherboard and RAM too.
The i5 2320 will bottleneck the rtx 2060 by large amounts of FPS a good pair of the 2060 would be the i5 9600k
Thank you @MVPernula and @Adsome2007
I will look into making a new build and will definitely consider the Ryzen 2600 and i5 9600k.
I appreciate the help.
No. consider 3600. next week sale.
2600 is 139.99 at microcenter and thats a really good deal. If you have access to it.
Current PC (Second Build) : CPU: Ryzen 5 1600 (OC @3.8GHz, sometimes pushed to 4GHz) RAM: 16gb Corsair Vengeance RGB Pro DDR4-2666 (OC @2733Mhz, sometimes pushed to 2800 for testing purposes)   GPU: PowerColor Radeon RX570 8gb MOBO: ASRock B450m Pro4 SSD: Inland 120gb HDD: 1tb Seagate Barracuda PSU: Cooler Master Masterwatt 500w Lite Case: NZXT H500 OS: Arch Linux+ KDE Plasma [Desktop Environment] & Windows 10 Pro [Broken due to grub 50% of the time]
Accessories: Mouse: Alienware AW958 Elite Keyboard: Corsair K63 Wireless  Headphones: Samsung Level On Pro
Phone (waiting on arrival): Samsung Galaxy Note 9
