Subwoofer doesn't connect to reciever
Jonathan=PC
802068948_WhatsAppImage2019-06-17at19_02_55.thumb.jpeg.042c51a39dc4e54886d8c7290222d9c7.jpeg925783227_WhatsAppImage2019-06-17at19_02_32.thumb.jpeg.5bdf8acf4731e40b9e2a1154c230b284.jpeg
Hello Guys
My Subwoofer has a different input then my reciever!
Is there something which can connect the two?
Everything Digital
1 minute ago, Jonathan=PC said:
Anyone???
What model receiver is it?
And either take meds or go for a walk.  No one needs to respond to you immediately ;)
Do you not have the entire Edifier C3X 2.1 setup?
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
If no one responds it get's burried and i can't buy any new stuff, before the store closes ;)
It's a Denon AVR-X1400H! :)
Everything Digital
RCA naar schroefaansluiting Aansluiting 2: Schroefaansluiting (2-polig)
Would something like this help?
Everything Digital
Yes i do, but i just bought a new reciever and going to hook up my two new T50's tomorrow.
Would like to use the subwoofer for my new 5.1 setup!
Everything Digital
If they work like they look like they are supposed to work, I would think so.  Never used something like that.
Btw, that AVR has assignable Surround Channels, so you could wire the Sub into one of them and change it in the system setup it looks like.
OnePlus:
Other Tech:
Don't care at all about the why you're spazzing out.  Just relax.  Double posting is against the forum rules anyway.
Edit:  Save up for a better subwoofer anyway too.
OnePlus:
Other Tech:
Thanks i'll try
Everything Digital
Thats understandable but please do not create new threads asking the same question, simply bump your old one.
-Threads merged-
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
Hello Guys
Youll need a mono power amp, the sub is passive and the RCA pre-out only supplies signal, not power. something like this: https://www.amazon.com/Audio-Full-Frequency-Switchable-Fosi-M02/dp/B07L4VMCRD/ref=sr_1_11?keywords=mono+power+amp%23&qid=1560798197&s=gateway&sr=8-11
(youll need a 1x rca to 2x rca to hook it up.)
LTT's Resident Porsche fanboy and nutjob Audiophile.
Main speaker setup is now;
Mini DSP SHD Studio -> 2x Mola Mola Tambaqui DAC's (fed by AES/EBU, one feeds the left sub and main, the other feeds the right side) -> 2x Neumann KH420 + 2x Neumann KH870
(Having a totally seperate DAC for each channel is game changing for sound quality)
Would this help me?
https://www.amazon.co.uk/Sinuslive-SUB-50-active-subwoofer-switch/dp/B003A5UOY4
Everything Digital
14 minutes ago, Jonathan=PC said:
No, that looks to be an active crossover network for a subwoofer. you need a power amp as the receiver handles all the crossover shenanigans
Btw, GG on getting a denon AVR, i used to run the denon avc - x8500H when i ran 15.2.5, they make good stuff.
Why wouldn't using one of the Surround channels and re-assigning it in the System not work?  It's a powered channel, no?
OnePlus:
Other Tech:
It could, it might be worth a try. But the chanels arent really designed to output tonnes of power in low octaves, so its a bit risky if the transistors arent up too it.
I'd argue that sub isn't going to need much power tho, with it's 45w rating. Worth a shot before buying an amp.  If you're going to spend money, buy a decent active sub.
OnePlus:
Other Tech:
True, im used to big subs lol. Tbf it would probably use under 20W before starting to distort and have cone breakup and what not.
Sort of, you can choose which extra 2 channels you have on top of a 5.1 system, but not reroute the LFE (sub channel) to a different output, from what I can see.
On 6/19/2019 at 4:21 PM, Derkoli said:
I'm used to big subs lol
lol...
9 minutes ago, anothertom said:
Sort of, you can choose which extra 2 channels you have on top of a 5.1 system, but not reroute the LFE (sub channel) to a different output, from what I can see. OP's best option.
lol...
Came from two SVS SB 1000's, probably getting a pair of rel's or two svs SB4000's, not too sure. :D
lol...
Good info, thanks for the clarification.
OnePlus:
Other Tech:
