Need help with my PC's Power Supply.
Narek
For the last week my PC froze twice(that never happened before). The first time it froze with buzzing sound in headphones. The second time it gave me the blue screen of death and automatically restarted. I decided to check it. And when I opened my power supply I noticed one of those battery looking things slightly moved and something spilled under them. The battery is to firm to touch(feels like that's the way to be). I never payed attention to the inside of my power supply so I am not sure if smth is wrong with it or not. I will attach photos of it. So please help. Tell me what to do. Do I need a new power supply? Is it risky to boot one last time to send some important files to my other device? (In case it needs replacement). Thank you in advance.
Those black batteries are capacitors and they must not be bulging. If you see that, you better buy a new PSU for your own safety.
Freezing and BSOD can be caused by unstable overclock btw. So there might be a correlation with CPU drawing more power and damaging your PSU.
Main system: Ryzen 7 7800X3D / Asus ROG Strix B650E / G.Skill Trident Z5 NEO 32GB 6000Mhz / Powercolor RX 7900 XTX Red Devil/ EVGA 750W GQ / NZXT H5 Flow
Those battery looking things are called capacitors. You shouldn't be really messing around with things like that, if you think it's faulty scrap it.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
Thx alot for the answer and advise. But one more question pls. Any idea what the orange spilled thing is?
electrolytic fluid.
زندگی از چراغ
They are specifically Electrolytic Capacitors and that is the electrolyte
FaH BOINC HfM
Bifrost - 6 GPU Folding Rig  Linux Folding HOWTO Folding Remote Access Folding GPU Profiling ToU Scheduling UPS
Systems:
desktop: Lian-Li O11 Air Mini; Asus ProArt x670 WiFi; Ryzen 9 7950x; EVGA 240 CLC; 4 x 32GB DDR5-5600; 2 x Samsung 980 Pro 500GB PCIe3 NVMe; 2 x 8TB NAS; AMD FirePro W4100; MSI 4070 Ti Super Ventus 2; Corsair SF750
nas1: Fractal Node 804; SuperMicro X10sl7-f; Xeon e3-1231v3; 4 x 8GB DDR3-1666 ECC; 2 x 250GB Samsung EVO Pro SSD; 7 x 4TB Seagate NAS; Corsair HX650i
nas2: Synology DS-123j; 2 x 6TB WD Red Plus NAS
nas3: Synology DS-224+; 2 x 12TB Seagate NAS
dcn01: Fractal Meshify S2; Gigabyte Aorus ax570 Master; Ryzen 9 5900x; Noctua NH-D15; 4 x 16GB DDR4-3200; 512GB NVMe; 2 x Zotac AMP 4070ti; Corsair RM750Mx
dcn02: Fractal Meshify S2; Gigabyte ax570 Pro WiFi; Ryzen 9 3950x; Noctua NH-D15; 2 x 16GB DDR4-3200; 128GB NVMe; 2 x Zotac AMP 4070ti; Corsair RM750x
dcn03: Fractal Meshify C; Gigabyte Aorus z370 Gaming 5; i9-9900k; BeQuiet! PureRock 2 Black; 2 x 8GB DDR4-2400; 128GB SATA m.2; MSI 4070 Ti Super Gaming X; MSI 4070 Ti Super Ventus 2; Corsair TX650m
dcn05: Fractal Define S; Gigabyte Aorus b450m; Ryzen 7 2700; AMD Wraith; 2 x 8GB DDR 4-3200; 128GB SATA NVMe; Gigabyte Gaming RTX 4080 Super; Corsair TX750m
dcn06: Fractal Focus G Mini; Gigabyte Aorus b450m; Ryzen 7 2700; AMD Wraith; 2 x 8GB DDR 4-3200; 128GB SSD; Gigabyte Gaming RTX 4080 Super; Corsair CX650m
Never open a PSU u can get a nasty shock.
If the PSU is faulty replace it.
MAIN PC (Beast) - Asus ROG Crosshair Hero VII WIFI  with BIOS 4703, AMD Ryzen R9 3900XT + Corsair H115i Pro RGB XT Cooling, 32GB G.Skill 3200Mhz 16,18,18,38 1.35v DDR4, Inno3d HerculeZ Design Nvidia GTX 1080 X2 8GB GDDR5,  1 x Samsung U28E590D & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 3TB Seagate Barracuda SATA III, 1 x LG BH16NS40 16x BR\DVDRW, ICYBOX IB3740-C31 & ICYBOX IB3640-03,  MZHOU 7 Ports PCIe USB 3.0 Card, 1 x XIAOLO 2.5G Intel I225V Ethernet Card, 2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Corsair Obsidian 750D Wind Force Edition Case + 5 Corsair ML140 140mm Case Fans, EVGA 750 g3 750w Gold 80+ PSU, Logitech MX Vertical Mouse, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, Synology ds215j NAS + 1x3TB WD Reds connected to a 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
if you have even basic electrical knowledge opening a PSU is perfectly safe. otherwise i agree.
1) Do not open a power supply unless you know exactly what you're doing, because it's an electrical hazard.
2) Those are capacitors, so clearly you don't know what you're doing.
3)
6 minutes ago, LinusTechTipsFanFromDarlo said:
electrolytic fluid.
That is glue that is used to reinforce through-hole capacitors. The capacitors are completely fine.
4) The capacitor has not moved, they are sometimes not centered on the markings on the PCB when soldered and that's fine.
You can DIE from the nasty shock. OP is really lucky if he messed with faulty capacitors without even knowing what they are and nothing bad happened
Ultra is stupid. ALWAYS.
Please do not disassemble power supplies if you don't know what you are doing. These are capacitors, and you can get hurt from a shock. I wouldn't even bother reassembling it now. Dispose it responsibly and get a new one. Something like a TX550 isn't to expensive and is of good quality.
Edit: the BSOD doesn't mean it's the power supplies fault, most probably not. While having PSU problems PC's usually just shut off.
Thank you for your advise. But for example what should I do if power supply fan gets dusty? How can I clean it without opening the power supply?
44 minutes ago, starcoaster said:
honestly that looks like the epoxy they use to make sure the caps stay stuck to the board. left hand cap looks a little bulgey but maybe that's due to the way it's sitting on the board as it looks ok from other angles
OP, do yourself a favour, don't open these again in future - capacitors store a fair amount of energy and unlike a battery will release it instantaneously the moment they get a chance. those two thicc bois are most likely mains filtering capacitors and will be charged somewhere between RMS wall power and peak wall power, so they will hurt. quite a bit.
looking by the genera construction of that PSU it seems quite old, maybe consider replacing it
if a capacitor vented badly enough  to spill goop out like that, you'd hear it hissing and definitely smell it
I guess it's old. I was using it since 2013. Thx for support.
Compressed air or a bicycle pump should work. But please, do not open it.
imlearning so much from here man. Im gonna start checking this stuff everyday
Yes, because your PSU is total garbage.
You can't "repair" it.
That's like trying to make an Opel Kapitän comply with modern Regulations. You just can't.
Just replace it with a somewhat good quality unit and don't bother with that piece of Pollution...
"Hell is full of good meanings, but Heaven is full of good works"
23 hours ago, LinusTechTipsFanFromDarlo said:
electrolytic fluid.
Really guys?
Ding ding ding!  Correct answer!
http://www.jonnyguru.com/forums/showthread.php?16642-What-is-quot-coil-whine-quot-and-what-is-that-white-stuff-all-over-the-inside-of-my-PSU
At any rate @Narek:  That PSU "may" have done you well so far, but that's an old Leadman made unit and is KNOWN to slowly kill other components with horrible voltage regulation and lots of ripple.  If it weren't for Leadman killing a bunch of PCs after a couple years of use and having to figure out why, I wouldn't have ended up as a PSU reviewer.
Replace it at your soonest opportunity.
