PG258Q how to turn on light in motion?
seger15
Hello! Yestarday i get my new monitor PG258Q i check everything g sync works correctly. But why my bottom led dosent work? Actually just couple time when i push him down he start flashing and gone. Any ideas? Because tbh i dont have clue about that :D  ( i use displayport cable)
Did you check the display settings? It should be right there for you to turn on.
 aHR0cDovL21lZGlhLmJlc3RvZm1pY3JvLmNvbS9S
If it does not turn on properly with the setting enable it might be a hardware issue. It has nothing to do with your display port cable.
AMD Ryzen 9 5900X - Nvidia RTX 3090 FE - Corsair Vengeance Pro RGB 32GB DDR4 3200MHz - Samsung 980 Pro 250GB NVMe m.2 PCIE 4.0 - 970 Evo 1TB NVMe m.2 - T5 500GB External SSD - Asus ROG Strix B550-F Gaming (Wi-Fi 6) - Corsair H150i Pro RGB 360mm - 3 x 120mm Corsair AF120 Quiet Edition - 3 x 120mm Corsair ML120 - Corsair RM850X - Corsair Carbide 275R - Asus ROG PG279Q IPS 1440p 165hz G-Sync - Logitech G513 Linear - Logitech G502 Lightsync Wireless - Steelseries Arctic 7 Wireless
But you a using pg258q?  Because at my settings i have just Level 0 Leve1 Level2 Level3 Dosent matter which one i choose still dosent work.  And what do you mean turn on properly? If u can please explain me because i am new with this system.. :D  So otherway send them to RMA?
