Is i3 8350k and rx 480 enough for 1080p 60fps gaming at high settings ?
Solved by Agonizel,
For the most part, yes.
But keep in mind that some (Jim's voice) "Triple A" games may be a bit too demanding and might dip below 60 at times. But for that you've got Freesync.
Competitive Gaming should be fine, but those are generally set on low anyway in order to see the essential better and faster
joshp305 ·
2
4
Inception9269 ·
Posted in PC Gaming0 -
1
1
2
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
