"Gaming" chair squeaking.. help save me
K i a r a
Hey
So, About half a year ago, around that I bought a "gaming chair" for around 200CAD (250USD)
Its no fancy brand or anything, but I still went for it, the main reason was I could remove the arms of the chair so it could be pushed into my desk closer, But this is beside the point.
The real issue I am having is the squeaking of the chair.. with almost ANY movement the thing squeaks... with the main movement when you lean back in the chair (not reclining just leaning to the back of the chiar.. or leaning forward...)
ANY suggestions on how to fix this, I do have WD-40 But i have no clue where I should be spraying it.
thanks
M Y  S T U F F
Ryzen  PC |~|  Ryzen 5 1600 | GTX 1060 6GB | G.SKILL Ripjaws V Series 8GB DDR4 DDR4 2400 x2 |  WD Blue 250GB SSD | Barracuda Pro 2TB  EVGA 650W 80+Gold |
Laptop |~| Legion Y530 | i7-8750H | GTX 1050 Ti 4GB | 16GB DDR4 2666MHz | 128GB SSD | 1 TB Hard Disk Drive, 7200rpm |
Macbook Air |~| 2.2GHz dual-core Intel Core i7 | Intel HD Graphics 6000 | 8GB of 1600MHz  512GB SSD |
Displays |~| AOC G2460VQ6 24" x2|
Keyboard |~| Corsair Gaming K70RGB
Mouse |~| Razer Lancehead Pink RG
Audio |~| HyperX Cloud II Audio-Technica ATH-AD700X
Microphone |~| Audio Technica AT2035
M y  R e v i e w s
Lenovo Y530 Legion Laptop.
More Coming Soon...
2 minutes ago, K i a r a said:
Hey
thanks
WD-40 all the things
That is all
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
That is all
yup wd-40 everything, i had squeaky headphones, wd-40, cabinet door was squeaky, wd-40, wd-40 everything
17 minutes ago, K i a r a said:
Hey
thanks
WD-40 isn't a a grease. It stands for Water Displacement - 40(th formula). You can put some WD-40 to see if the squeaks go away, but it would be temporary, and I would expect the squeaking to come back. Try it with some WD-40. If the squeaking comes back, get some real grease.
In my experience this is typical of most chairs after a while, not necessarily with any correlation to price.  I'm currently using a $90 IKEA chair that feels more solid and premium than anything I've had previously despite this also being my cheapest one yet.  I also look for chairs without arms, or at least with removable arms, partly for the reason you mentioned, but party just because I don't use them and they would get in the way.  I know you're not shopping for a new one at this time but just some tips to keep in mind.  Hopefully you can fix the squeek.  My advise would be to listen around the frame for the source then inject the problem area with a lot and hope for the best.  It may take a few movements to let it really get in there though.  If you can't find the source by ear, I'd just target anywhere two pieces of metal touch - screws, plates, hinges, etc.  One solid piece of metal isn't going to squeek, it must be cause by it rubbing on something else.
WD40 sucks for lubrication, and it can ruin rubbers. I would use penetrating oil, or seweing machine oil. On larger joints you can use bearing grease. Simply lubricate all joints on this chair. Be careful not to make a mess.
On every joints it has. Just shoot them all with WD40
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
  • 2 years later...
you may also try something like superlube, it is a very good lubricant, it is quite thin tho so consider that, if that dosent work using some sort of grease might be your best bet, or using a bit of motor oil
