Audio-Technica ATH-M50X vs Beyerdynamic DT 770 PRO 250 ohms
Solved by rice guru,
1 hour ago, JHurley7nrx said:Im now actually thinking of buying the dt 990 pros because the are open back, I see you have them listed in your profile what are they like for lows without being equalised.
not as good as the 770's sound wise IMO. mine are pretty heavily eqd to suite my tastes. but stock they have more pronounced mid bass and highs and the highs can be too much for most people some times a little sibilant. while the 770's have a clean low end emphasizing sub bass the 990's have a clean low end emphasizing the mid bass. The are alittle wider sound stage wise and imaging and separation are about the same.
