What to do after changing cpu/ram/psu/motherboard?
Solved by Kaicer,
7 minutes ago, exon654 said:Let's say I've changed CPU/RAM/Motherboard and a PSU, what is the next thing I should do? Do I boot my pc through my flash and install windows? I'm a little bit confused, step by step explanation would be very useful and appreciated.
Download Windows (10/7/8.1/etc.) onto the USB drive with another computer and plug the USB drive into either the front or back USB ports.
Then proceed to mash the life out of the key that allows you to select your boot drive in Bios and select the USB drive. Then hit enter once you select "Yes boot from this drive" (or whatever it says for you.)
