Radeon VII - Unexpectedly low frame rate in GTA V
BecauseICanTBH
I just got my Radeon VII today and installed it. It was an upgrade from the RX580.
I'm only getting about 20-30 FPS in GTA V on the highest settings. Much better than the RX580, but still quite a bit less than I expected.
Anyone have an idea of a setting in the AMD application that maybe I'm missing?
How about tell us your full specs and what resolution and settings you're trying to play at?
Personal Desktop":
Luna, the temporary Desktop:
Specs:
Intel i7-8700k (no overclock, Noctua NH-D15 cooler)
32 GB HyperX DDR4 @ 2666MHz (4x8GB)
MSI MEG ACE Z390 Motherboard
WD Black SN750 NVMe Drive
MSI Radeon VII GPU (no overclock)
750W Seasonic PSU
Windows 10
AMD Settings:
GTA settings:
Ignore suggested limits: On
DirectX Version: 11
Screen type: Fullscreen
Resolution: 1920x1080
Aspect Ratio: Auto
Refresh Rate: Auto
Output monitor: 1
FXAA: On
MSAA: x8
VSync: On
Pause on focus loss: On
Population density: 100%
Population variety: 100%
Distance scaling: 100%
Texture quality: Very high
Shader quality: Very high
Shadow quality: Very high
Reflection quality: Ultra
Reflection MSAA: x8
Water quality: Very high
Particles quality: Very high
Grass quality: Ultra
Soft shadows: AMD CHS
Post FX: Ultra
Motion blur strength: ~20%
Depth of field effects: On
Anistropic Filtering: x16
Ambient Occulsion: High
Tessellation: Very high
Long shadows: On
High resolution shadows: On
High detail streaming while flying: On
Extended distance scaling: 100%
Extended shadows distance: 100%
Frame scaling mode: Off
With those settings I get 20-30 FPS, with the graphics card and CPU both running cool (~70C). GPU is at 100% and CPU is at about 20%. RAM usage is about 7GB total and VRAM usage is about the same.
3 minutes ago, Firewrath9 said:
drivers?
Radeon Software Version 19.4.1
That makes 0 sense...
Check GPU Clock speeds, but either way, you say this is better than what you got with the RX 580, that also makes 0 sense at 1080p.............. what?
Quote or Tag people so they know that you've replied.
you should get way more than 30, esp. at 1080p. What are some benchmark scores such as time spy, heaven, etc.
Turn off Vsync i guess?
That's what I was thinking. Shouldn't I at least be stable at 60+?
I will come back in a bit with some benchmarks.
Okay wait, reset "Global Graphics" first, don't use supersampling and such
I reset all of the AMD settings, and it seems all that changed was that the frame rate is now more like 20-25. I'm going to run some benchmarks now
I used the extreme preset with nothing running in the background, and got these results. Does that look normal?
Try turn off everything in Advanced Setting or set to lowest.
Then set MSAA to 4x
Turn off Vsync
Did you use DDU after swapping GPU’s?
could be a driver issue
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
Turn vsync and any sort of triple buffering off
-13600kf
- 4000 32gb ram
-4070ti super duper
I did a CMOS reset and a fresh installation of Windows.
Then set MSAA to 4x
Turn off Vsync
VSync didn't seem to make much of a difference, but MSAA made a pretty huge difference. Turning MSAA from x8 to x4 bumped my frame rate from 40s to 80s. Turning it off brought me over 100.
These are my new AMD and game settings, and with this I'm sitting at about 160 fps. Very cool. Thanks a bunch guys.
DirectX Version: 11
Aspect Ratio: Auto
Refresh Rate: Auto
Output monitor: 1
FXAA: On
MSAA: Off
VSync: Off
Reflection MSAA: x8
Post FX: Ultra
Motion blur strength: 100%
Long shadows: On
  Reveal hidden contents
DirectX Version: 11
Aspect Ratio: Auto
Refresh Rate: Auto
Output monitor: 1
FXAA: On
MSAA: Off
VSync: Off
Reflection MSAA: x8
Post FX: Ultra
Long shadows: On
Just out of interest I bet u maxed the res scale by accident so I’ve been running 4k 8xmsaa
which is what ur performance lined up with
-13600kf
- 4000 32gb ram
-4070ti super duper
