Cables on side of GPU yanked
OnlyAxolotl
There are two pin connectors on the side of my GPU (Gtx 1070). They aren't the power connector, I assume they are for fan controls or something else?
During installation I pushed up to lift my gpu and yanked one of them, there is no obvious damage but I have been getting really low frame rates. The temps never go above 60c
Pic?  I have never had a GPU that had extra wires to it outside of power.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
DIL: Ryzen 7800X3D - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 CL6000CL32 32GB - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w -NZXT H5 Elite
Emma: i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
The fan shroud (with fans attached) usually has cables to the pcb.
Pics would help indeed, and gpu temp normal but low perf might indicate power throttle (vrm overheating due to lack of cooling if the fan on that side doesnt spin perhaps).
Just guesses without pics, and report if all fans spin under load or not?
https://imgur.com/z53GBlD
Those cable on the bottom right are the ones. Surely my GPU would be reporting the right temperature.
 Thanks for the img! Looks like a strix? nice!! Do all fans spin?
Have you use hwinfo64 and monitored not just "gpu temp" but also "gpu vrm temp" (not sure if that card has that sensor though). I have strix 2060, it also lists 4 sensor for throttling (temp, voltage stability, power and one i cant remember right now). Maybe that can indicate low fps reason.
If its a strix indeed and you mean the connectors (so not the red blue green yellow connected in the pic) its probably the fanconnect headers (if fan or fans where connected you can prolly find the yanked cable and plug m back in)
