Laptop shuts down under CPU load ONLY on battery. (and 135Mhz GPU lock on battery)
I have a Precision M6700 with a quadro K3000M and i7 3720qm, if I connect to AC power there is no issues, quadro goes to 650+Mhz and doesnt shutdown under CPU load (though it gets quite hot, 85-95c). But if I unplug it the GPU immediately drops to 135Mhz and within a few seconds of starting a CPU stress test the laptop shuts off.  The error in the BIOS says 'ASF2 force off', looking that up doesn't seem to help, there are some people saying its battery, some saying it's main board, some saying its GPU, CPU, etc.  I have an extra main board that I will swap in tomorrow and see if the issue still persists.  The dell pre-boot diagnostics shows everything as passing and the shutdowns are there under any OS, I tried Hirens 2, Windows 10, and it even shutdown on the Dell pre-boot diagnostics under CPU test (which just stresses the CPU).  I can't imagine it's the CPU though because it only happens on battery power.  The GPU issue is less of a deal for me, the K3000 in the laptop is limited to 135Mhz on battery, I've tried power settings, new drivers, old drivers, nothing seems to make a difference.  I am waiting on a GPU upgrade anyway so the main point of this is to fix the shutdown under CPU stress tests on battery.
why no dark mode?
Current:
Watercooled Eluktronics THICC-17 (Clevo X170SM-G):
CPU: i9-10900k @ 4.9GHz all core
GPU: RTX 2080 Super (Max P 200W)
RAM: 32GB (4x8GB) @ 3200MTs
Storage: 512GB HP EX NVMe SSD, 2TB Silicon Power NVMe SSD
Displays: Asus ROG XG-17 1080p@240Hz (G-Sync), IPS 1080p@240Hz (G-Sync), Gigabyte M32U 4k@144Hz (G-Sync), External Laptop panel (LTN173HT02) 1080p@120Hz
Asus ROG Flow Z13 (GZ301ZE) W/ Increased Power Limit:
CPU: i9-12900H @ Up to 5.0GHz all core
- dGPU: RTX 3050 Ti 4GB
- eGPU: RTX 3080 (mobile) XGm 16GB
RAM: 16GB (8x2GB) @ 5200MTs
Storage: 1TB NVMe SSD, 1TB MicroSD
Display: 1200p@120Hz
Asus Zenbook Duo (UX481FLY):
- GPU: RTX 3050 Ti 4GB
RAM: 32GB @ 4800 MTs
Storage: OEM 1TB M.2
Display: Main 1800p@120Hz OLED + Screnpad Plus 2880x864@120Hz
Custom Game Server:
CPUs: Ryzen 7 7700X @ 5.1GHz all core
RAM: 128GB (4x32GB) DDR5 @ whatever it'll boot at xD (I think it's 3600MTs)
Storage: 2x 1TB WD Blue NVMe SSD in RAID 1, 4x 10TB HGST Enterprise HDD in RAID Z1
 Sounds 100% like battery to me.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
I thought that as well, but this battery is pretty new (like 2-3 months old) and everything shows it as working fine, Ill swap in the board tomorrow and if it still shuts down I'll probably end up replacing the battery...
why no dark mode?
Current:
Custom Game Server:
Sounds like a plan. Some batteries are defective, this may be one of those. Was it an OEM battery? If you bought a cheap china battery it may not be up to the task.
Useful threads:
Total: $1891.98
I bought it from eBay as an OEM battery, and it looks legitimate, but I have no guarantee of it.
why no dark mode?
Current:
Custom Game Server:
Seems legit to me, but i don't have much to compare it too. Get back to me when you replace the mainboard and see how it does!
Useful threads:
Total: $1891.98
Will do, it should be around 4-5 pm EST tomorrow :)
why no dark mode?
Current:
Custom Game Server:
Swapped the boards and the issue is still there, leading me to believe its probably the battery, too bad my return window is like 2 months past :/
why no dark mode?
Current:
Custom Game Server:
