Thin Walls, Would Sound Absorbing / Acoustic Panels Help?
Solved by Slottr,
Just now, TeenTesla said:I feel like the frame in the video is the only thing that redeems it, and makes a world of difference. I don't mind a cool blanket on the wall or whatever, I'm really just concerned about the edges. I want sharp, straight edges like you'd get from a frame, and not like you'd get from a folded blanket haha. But maybe there is another solution I haven't thought of?
Any ideas there?
If you really want that frame look, if you go to a large hardware store that cuts wood, you can give them the dimensions of the pieces you need cut and they'll do it for you- then you just put it together
