PSU Wattage for Build
Half Life
Hi guys.
A few months ago I started the construction of a new PC. I bought some components, but I do not know what power PSU is enough for my build.
I like do OC and I plan to do OC only to my CPU ~@5.0GHz.
I have:
* i5 9600K
* MSI MPG Z390I
* EVGA GTX 1070 SC
* 16GB Vengance LPX @2400
* 2 SSD (2.5" and M.2 PCIe)
* Alphacool Eisbaer
* 4 Corsair SP120 HP
I have money for a 750 Gold or 650 Platinum.
The results from OuterVision PSU Calculator.
Thanks!
PS. I'm not from USA
A 650Watt will be more than ample for u.
Make sure its Atleast a Gold + Rating.
MAIN PC (Beast) - Asus ROG Crosshair Hero VII WIFI  with BIOS 4703, AMD Ryzen R9 3900XT + Corsair H115i Pro RGB XT Cooling, 32GB G.Skill 3200Mhz 16,18,18,38 1.35v DDR4, Inno3d HerculeZ Design Nvidia GTX 1080 X2 8GB GDDR5,  1 x Samsung U28E590D & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 3TB Seagate Barracuda SATA III, 1 x LG BH16NS40 16x BR\DVDRW, ICYBOX IB3740-C31 & ICYBOX IB3640-03,  MZHOU 7 Ports PCIe USB 3.0 Card, 1 x XIAOLO 2.5G Intel I225V Ethernet Card, 2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Corsair Obsidian 750D Wind Force Edition Case + 5 Corsair ML140 140mm Case Fans, EVGA 750 g3 750w Gold 80+ PSU, Logitech MX Vertical Mouse, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, Synology ds215j NAS + 1x3TB WD Reds connected to a 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
7 minutes ago, Half Life said:
i5 9600K
MSI MPG Z390I
EVGA GTX 1070 SC
A decent 550W unit will do the job. I recommend getting a Corsair RMx unit.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
The 1070 is a 150W card, so expect the system to draw about 250W under full load. A good 450W is absolutely plenty.
The 80+ rating says nothing about how good a PSU is. E.g. the EVGA G1 NEX 650W is 80+ rated, yet it's absolute dogshit garbage. You have to look at the PSU model. Where are you buying from?
Oh, it's great hear that.
Thanks, I have on target Seasonic or Corsair.
I'm from Mexico, and I have a gift card on Amazon. So I will buy there.
Why are people still using it?!
ITs overestimating by a mile.
They make money with the affiliate Linsk they have on the site.
Anyway, without OC; a high quality 350W should be enough, 450W to be on the safe side.
And for future upgrades a 550W might make sense.
650W is mostly useless, even today.
"Hell is full of good meanings, but Heaven is full of good works"
You should look on everything, including but not limited to:
Be quiet, Bitfenix, Cougar (are they still around??), Silverstone.
They also have nice units.
If you don't plan on Ultra High ENd hardware, 450 or 550W Bitfenix Formula or Whisper M is a good choice, be quiet Straight Power 11, Cougar GX-F, Silverstone Strider Platinum.
lol
I know but on the problem it's the resellers in Mexico. They import the most common brands and if I want a specific brand I need import and the shipping and taxes increase to much the final price ?
Just look at the Tier list and pick the best one in the top 2 tiers that they have, I would say go with 650W for future upgrades, GPU and or CPU. The good units have long warranties so they will last a few builds/upgrades etc.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
Well PSU calculators in general are least a good base line, but there is always room for margin of error.
And all PSU calculators are affiliated with one PSU maker or another.
I usually recommend at base 550W or 650W for a gaming PC, 550W is usually suitable enough.
The only reason why i would recommend a 650W is if its at a good price and has a good rating on the PSU tier list.
5GHz is a really common overclocking goal for those CPUs so there are actual reviewers that test the power consumption at those overclocks.
Like this one from Tom's Hardware https://www.tomshardware.com/reviews/intel-core-i5-9600k-coffee-lake-cpu,5922-2.html
180W with really stupid heavy power draw from full artificial AVX stress testing. Not really typical results if gaming or whatever...
115W with more realistic load testing, more comparable to gaming consumption... Gaming maybe even a bit less.
Same thing again for the GPU, look up power consumption results for the graphics card. You'll see it's spec'd at 150W, but can probably push it as high as 200-225W if you increase the clocks and move the power target slider.
https://www.tomshardware.com/reviews/nvidia-geforce-gtx-1070-8gb-pascal-performance,4585-7.html
Just keep in mind if you look up power consumption figures check out how the reviewers measure it, what tools they're using and if they're doing individual component measurement (most accurate) or if they're just doing total system power draw.
Running synthetic stress tests like Prime95 + Furmark on the CPU and GPU at same time looking at maybe up to 400W combined on CPU & GPU. More realistic gaming loads like <300W combined CPU & GPU.
System should run perfectly fine on any good quality 450W PSU, even with a 5GHz OC on the CPU. Go 550W if you really want to or if you plan on upgrading the GPU. No need for 650W or 750W with your system (though if you're looking specifically for an 80+ Platinum unit a lot of those start out at 650 or 750 watts).
If market isn't very good there, you're probably going to be paying through the nose for any 80+ Platinum units, I'd probably just settle for looking at units with 80+ gold efficiency ratings and save your money.
The cheapest platinum units I see on Amazon Mexico is the Seasonic Prime Ultra Platinum 550W, or the Corsair HX750 (non-i) which are both for about 3000 pesos, or about $160 USD.
If you're willing to settle for 'only' 80+ gold, then just grab the RM550x (2018) for 2000 pesos ($105 USD) instead.
Find a unit Tier A+. Gold is enough.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
I decided and I'll buy the RMx. For less $10 USD more I can go for the 650 version. I should buy it or save the money for anything else?
Sure, I'll go for the RMx.
Thanks!
Other than the obvious wattage difference between the two, the RM650x (2018) has an additional PCIe and SATA connector on the modular interface on the unit, and comes with an extra PCIe cable and SATA cable in the box.
RM550x (2018) will be fine for your system, but if you're planning on changing to a high power draw card like a 1080Ti, 2080Ti, Radeon VII, Vega56/64, then get the RM650x (2018) for the extra PCIe connectors so that you can have each PCIe connector plugged in to the GPU coming off an individual connector on the PSU side (without having to buy extra PCIe cables from Corsair). But that's not an issue with your GTX 1070.
Well in that case, I think it's convenient buy the 650 version, cuz in case if i need the extra cable, to buy it wil be the price for the cable plus shipping and tax. And I'm sure that will cost more than 10 extra bucks.
Well guys, searching on online country stores I found a Seasonic Prime Gold 1000W for ~$130 USD including shipping and taxes.
Thanks for the help!
