My predictions for Zen 2
I am not an AMD employee, afilliated with AMD or have access to inside information at AMD. This is just pure speculation.
jjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
Expected clock speeds and wattage for Zen 2:
  • ATHLON line: 3.5GHz-4GHz at 35W-55W
  • RYZEN 3 line: 3.8GHz-4.4GHz at 45W-95W
  • RYZEN 5 line: 4.1GHz-4.7GHz at 65W-105W
  • RYZEN 7 line: 4.3GHz-4.9GHz at 95W-145W
  • RYZEN 9 line: 4.6GHz-5.2GHz at 125W-185W
  • THREADRIPPER line: 4.7GHz-5.5GHz at 125W-280W
Expected launch date should be Computex; L2 and L3 cache should double, and single-core should increase by 20% and IPC by 10% (higher single core does not always correlate to higher IPC, but higher IPC always correlates to higher singlecore; IPC is instructions per clock and single core is 1 core)
Some confirmed facts are that AVX2 performance should double, and that Ryzen performance should perform a higher tier than current Ryzen (i.e. Zen2Athlon performs like Zen1r3, Zen2r3 performs like Zen1r5, Zen2r5 performs like Zen1r7).
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
I think the entire performance tier will go up, not just each processor. If a Ryzen 5 3600 performs as well as a Ryzen 7 2700, that's a little disappointing. Even the base model Ryzen 3 should be beating the high tier Ryzen of last gen in single threaded, if meaningful gains are made, especially going on that CES demo.
Primary PC:
I would be really happy with ryzen 9 at 4.9ghz, how ever, if it is really 5.2ghz i will take it,
BUT threadripper at 5.5ghz makes no sense, as more cores = lower frequency, so if threadripper is 5.5ghz, then i would expect the same from ryzen 7-9.
I only see your reply if you @ me.
This reply/comment was generated by AI.
It's all about that sweet 5GHz barrier. If they can actually hit that it's gonna be sweet.
@Origami Cactus
More cores, but they will limit the turbo anyway to less than all cores. Threadrippers do use higher binned chips so it's possible that's the reason. But you can't expect 32 cores to run at 5.2GHz. If they can get 8 I'd be amazed.
hopefully they can redeem themselves from attempting 5ghz with bulldozer
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
As a SFF enthusiast, I'm more hyped for better efficiency than faster speeds. If I can get a Ryzen hex core that runs well at ~40 watts, i'd be a happy man.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
Rip literal melted motherboards, the 9590 was a grim reaper indeed.
Primary PC:
oh god some more fanboyism
Desktop benching:
not really actually, this is pretty much expected
where do you base your expectations from? It's not like someone else has built a CPU with TSMC 7nm before
Desktop benching:
There have been quite a lot of leaks, but here's a Athlon/Ryzen 3 that was leaked. Same performance as a 1600
https://ranker.sisoftware.co.uk/show_device.php?q=c9a598d994d0f0b5dbbc9ccfaec3b3dfba80a092d685b484b0f2b0fdc98ec6f4ab98a08fbc88d799bfd8e5c8f9dfad90a086efd2e3c5ad90a583fbc6f7d1b4d1ecdcfa89b48c&l=en
Plus it's a completely new "architecture" compared to Zen
Gaming performance =/= synthetic performance aside, how could you predict frequency and TDP based on that?
Desktop benching:
This is interesting. 5.5ghz on a 16 core threadripper is a little bit too much for my liking. Considering the 1950x went up to 4ghz and the 2950x up to 4.4ghz, I think 5-5.2ghz is reasonable. I wouldn't rule out 5.5ghz given the jump from 12nm to 7nm is far larger than the 2nm shrink last time out, but I do think 5.5 is too good to be true. If it did reach that though, then Intel is in serious bother.
So according to AMD's specs, that indicates that for every 1nm shrink, 200mhz is added on threadripper (It's definitely smaller on normal ryzen though). That would indicate 1ghz more. Which is 5.4ghz, so not too far off what you've said. I still think 5-5.2 is more reasonable.
As long as we get 5.0ghz on some of the chips, then I'm happy and I think everyone else would be too. Anything higher is a bonus.
The most interesting thing for me is how AMD approach this launch. Do they focus heavily on clock speeds and give the chips really high clocks out of the box, or do they promote the efficiency of the chips instead, and amaze everybody by the crazy overclocking potential on them. I think they should go for the latter personally (They went the efficiency route at CES comparing it to 9900k, I expect them to continue that).
If we get 5ghz, I can finally replace my fiery FX9590 with a real successor. Can't wait.
You would be a fine addition to ?️rainletstations.
"gg amd"
8086k
aorus pro z390
evga 3070 ultra
because it says so in the engineering sample's name? 65W 4c/8t
then please explain how that's read, I don't see how "2DS104BBM4GH2_38/34_N (4C 8T 3.8GHz, 733MHz IMC, 4x 512kB L2, 2x 8MB L3)" shows 65w.
Desktop benching:
