CPU high temps in BIOS (Need help!)
Hello, so I'm having a serious issue with my computer. I was on Windows 7 and I decided to finally upgrade to Windows 10. The installation went fine and all but once I was able to login I got a random blue screen and I wasn't able to get the error code to look up the stop error. Then my fans for my corsair H100iv2 started to spin up fast. once my computer restarted I looked into the bios and it was really high in temps, like it started at 60c or 70c then it started to rise up to high 80s and hitting 90C. I feel like my pump died but I would like to see what all of you who are reading this have to say. If any of you need more information I will gladly explain to all of you.
Thank you.
Sounds like a dead pump, but remount the block try to see if you can feel any vibration from it.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
Are you able to stay in Windows long enough to get Corsair Link opened? If you hooked up the Corsair Link shit on your cooler you should be able to get a report on pump speeds.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
The thing with that is ever sense I got my cooler it would always show 0rpm in the corsair link and in iCUE. i have looked up fixes in the past to see if I can see the Speed of my pump. I can see the fan RPM changing but not my pump speed.
Wouldn't I need to reapply thermal paste if I remount the CPU block? I don't have any extra thermal paste I used the thermal paste that was already on the block.
Are you sure its hooked up right? You have the mini-usb cable that plugs into the block and runs down to the USB header. Then you plug your fans into the cooler itself, rather than the CPU fan headers on the motherboard iirc. Should be able to see pump and fan speeds that way.
PC #1
PC #2
Corsair H80iGT AIO
Laptop
you can use the same thermal paste fine; if it's really crusty though i'd order some and change it later.. Also, maybe touch the block and feel how hot it is, or install a stock fan cooler if you have one
That's the way I have alwaysed had it.
Unplug each fan and harddrive (basically anything that makes noise) and fire it up. Put your ear up to the block and see if you can hear the pump running.
PC #1
PC #2
Corsair H80iGT AIO
Laptop
I'm going to test I then again and see if I feel anything from the pump. I do have the pump plugged in the CPU_FAN which is the main one and in the BIOS I do have CPU fan error on so wouldn't it tell if the pump is dead?
could it be if you have a pci to usb header, that you may need drivers for W10 for it to engage and power the pump? Probably not at all, but just a thought
I have the USB connector on the NZXT internal USB hub which is connected to the motherboard. I will connect it USB connector on the motherboard without the hub.
So I turned on my PC and felt my pump to see if I felt any vibration or anything and I didn't feel anything. So I'm guessing my pump died?
Its possible, but take a look at this video and see what you can do.
PC #1
PC #2
Corsair H80iGT AIO
Laptop
don't those things have pretty good warranties? If shipping doesn't cost much i'd just stick on a standard air cooler and RMA it
Guess thats a good point lol. Forgot all about warranty.
PC #1
PC #2
Corsair H80iGT AIO
Laptop
