need help with build.. pc for 3dsmax
Solved by cluelessgenius,
depends on wether you wanna do cpu or gpu rendering among other things. check out this benchmark for example
https://www.cgdirector.com/vray-benchmark/
not much difference from 1700 to 2700
also gpu wise id stick to nvidia just because 3d modelling of any kind the software has always favoured sometimes required nvidia.
runningdecoy ·
Posted in Troubleshooting0 -
joshp305 ·
Posted in New Builds and Planning1 -
3
4
Inception9269 ·
Posted in PC Gaming0 -
1
2
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
