Balanced Power Plan Causes Micro Stutters
RocketJump
Go to solution Solved by Chronified,
The first thing you should do when you set up Windows for gaming is to move windows into High Performance mode. Balanced and Power saver work by reducing the clock speed, or when not possible it reduces the effective percentage of the CPU that can be used by programs. (click advanced and go to the CPU section to see).
PCIe powersaving is also used in some systems through that menu, which can cause GPU bottleneck.
Best thing to do is make a custom plan and max everything out, including HDD/Screen times (just put 0 and it'll set to never)
tl;dr
25 minutes ago, Streetguru said:
 just windows being windows
Does anyone have any idea why setting my power plan to "balanced" causes micro stuttering in games? At first, I thought it might have been something to do with my OC but this happens even on stock settings. I was hoping I didn't have to manually switch profiles every time I launch a game. My setup includes an 8700k, Kraken x62, GeForce GTX 1080 FTW2, RipJaw V DDR4 3000, Aorus Gaming 5, and a Corsair RM 650i.
MSI Prestige 15
i5 10210u - 8GB DDR4 2666MHz - GTX 1650 Max-Q - 500GB SSD
Hinges still intact!
It's probably just windows being windows
tl;dr
My rig:
CPU: Ryzen 5 3600 3.6Ghz, OC'ed to 4.2Ghz all core @ 1.25v + Corsair H60 120mm AIO
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
tl;dr
Thanks for the reply. I was hoping there was an alternative way to handle this. I set up my OC with an offset so I could take advantage of adaptive voltage and was hoping to keep speedstep enabled. I guess I'll just switch profiles while gaming.
MSI Prestige 15
