FPS problem on i7 8750h and GTX 1060 laptop
Hey guys, I got a i7 8750h and GTX 1060 laptop recently and I am getting rather strange FPS values. I am getting around 40-100 FPS in CSGO on all low settings. Same thing is happening for all games like Witcher 2 and 3, The Division and on and on... So I got a few theories.
1- It can be a driver problem. And I do not know how to solve it.
2- When I was playing CSGO, I plugged in an external monitor to check the task manager. I saw this (check attachments). I would have expected at least 3.6 GHz from this CPU. And you can't see it here but when I play games the iGPU usage is about %30. So I think the CPU's slowing down to feed iGPU.
3- It could be some other software problem like BIOS.
So things I have tried so far includes:
-Reinstalling Windows.
-Deleting drivers using DDU.
-Setting the game for Nvidia GPU on Nvidia control panel.
-I have tried both unplugged and plugged to the wall.
-I have tried disabling the iGPU but games won't open for example cs is giving engine error (check attachments)
-My drivers are up-to-date.
-When I try to install iGPU driver from Intel's site it says you can't (check attachments).
-My power management setting are set to maximum performance.
-My temps are fine. Not above 70 degrees celsius.
What is happening ? Can we solve this problem ?
When working on laptops, the first thing to check are the temperatures. Get HWinfo and run it in sensor mode
The iGPU is used by the 1060 to send 3D data to the monitor, that's probably why its used
Desktop benching:
Like I said, the temperatures are fine. It must be something else.
You only gave numbers for the core temperature, some laptops have extra thermal sensors for other parts of the motherboard
Desktop benching:
Yeah sorry for that, but other temperatures are about the same like if the CPU is around 65 degrees then for example GPU is about 59 degrees. The laptops cooling system is quite good and like I said I recently bought this so fans are clean.
what about the power limits? Some laptops come with bios that locks the CPU below 45w Intel spec
Desktop benching:
All I got are these. Check them out since I am not really familiar with laptops.
are these the numbers after playing a round of games? Because the 1060's usage is very low and an indication that it's not being used.
Desktop benching:
These are idle numbers. And I do think when playing games it would be similar. Not the same of course, the numbers would be higher.
but how much higher? From your screenshots I can see it's hitting the power limits even though you maxed out at 23w (yes, HWinfo cannot read PL1 and PL2 perfectly)
Desktop benching:
Could you monitor CPU+GPU temps+clock speeds via Afterburner+Rivatuner+HWinfo64 instead of using external monitor?
Try undervolting and using Speedshift 1 via Throttlestop. Also, I noticed that your RAM usage is quite high. Suggest adding another 8GB stick for dual channel and larger memory capacity
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
I played some PUBG and I do not think it is about the iGPU. The clock speeds are pretty off. I am posting a photo in the attachments.
Well look at the PUBG photo. If I could just only figure out what is wrong with this PC.
seems like the CPU isn't boosting high because there's no need to, CPU usage isn't high and PUBG dont really demand much from the CPU
it does have high memory bandwidth and latency requirements, are you running single channel memory?
Desktop benching:
Yes I do. One stick of 8 GB 2666 MHz RAM.
That's your bottleneck then, you only have just over half the memory bandwidth of those running dual channel
Desktop benching:
It might be. But my other PC, which has i7 2600 and it used to have a r9 270x played like a dream. 250+ FPS with just shadows set to low (CSGO). And it has DDR3 8 GB but it did run on dual channel. I researched the benefits of dual channel before but the performance is still just absurd in my opinion. You really think it is because of single channel ?
this is running 3000MHz CL16 already, with your 2666MHz CL19 the difference between single and dual channel will just widen
Desktop benching:
You know I'm kinda beginning to believe it is about dual channeling. But can single channel affect CPU clock speeds that much ?
just part of power saving tech, it wont ramp up the CPU when it wont help anyway
Desktop benching:
That makes a lot of sense. Thank you so much.
