Difference Between EVGA GTX 1070 sc and 1070TI sc
ivanteng880
Go to solution Solved by Jurrunio,
4 minutes ago, ivanteng880 said:
I just have one more question. I found this video of this guy taking apart the same card I have. But the thermal pad isn’t covering those block thinys. Any Explanations ?
those are inductors, a box with coiled up wires. The most heat resistant part of a graphics card. Dont need cooling.
Hi guys, I want to replace my thermal paste on my EVGA GTX 1070 TI SC Black Edition the next time I dust out my PC, and so I went on google and tried to find a video but every single video I found is about EVGA GTX 1070sc/ 1080sc. So I'm wondering if there a massive internal difference between the EVGA GTX 1070TI sc and the EVGA GTX 1070sc/ 1080sc. Thank you, any suggestion helps.
Oh, and one more question, I tried to open my card to replace thermal paste, but I forgot to buy thermal pads for my GPU (LOL, I know, I'm stupid). By the time I realized that I forgot to buy thermal pads, I've unscrewed all but one screw on my GPU, and without thermal pads, I just screwed every screw back in (the one in the very corner, the four screws around the GPU die is unscrewed). Is that bad for my GPU? (Thermals look ok, 71C under full load in heaven unigen, and fan speed is at 70%, almost the same as before, 71C with fans at 65ish percent)
Same PCB and cooler for 1070Ti and 1080 on pretty much every brand, every model.
you dont have to replace thermal pads if you havent broken them
Desktop benching:
Well, I did some research on google and got some mix result on reusing thermal pad, plus I don’t trust my self not to tear the thermal pad. But is it bad that I took off all the screws without replacing the thermal compound?
air bubbles could form and ruin the thermals
Desktop benching:
Desktop benching:
I’m sorry if I’m asking too much question. I just want to know, how durable is a thermal pad? Does it rip really easily?
if it's sticky, it can rip if not careful. Otherwise it should come off relatively easily
Desktop benching:
One very very last question. So as long as the thermal is still good, (assuming 70C is good) I’m good right? Because I’m going to do a complete cleaning of my PC in the summer. So I can clean everything at the same time.
yes
Desktop benching:
