My graphics card does not "fully" work, pls help me.
So, my friend has a computer with does not have a graphics card. I gave my old card to him and went over there to intall it. It's a Geforce 960 2gb btw. When everything was plugged in and we fired up the pc I worked fine. Until we started CSGO and it would not start, it popped up a window how said that it did'nt work aswell with a lot of numbers, i don't remember. Then I started LOL with worked, we got into a game and everything. Just that it was an avrege of 2 fps. So o thougt that it might be the drivers who needed an update but when i had downloaded the update, i wasn't compatable for some reason... I don't know what to do fron here, pls help me!
With regards...
With regards...
did you download drivers with geforce experience?
I installed it from nvidias wedsite
1 minute ago, Alexsolo said:
Is your monitor plugged into the graphics card? Or is it plugged into a video output on the motherboard?
It's plugged into the graphics card
Just now, Alexsolo said:
Did you plug in the 6pin PCIe power connector from power supply to the GPU?
Yes
could you provide the error code exactly? perhaps next time you're with your friend...
It would give a better indication of the source of the problem.
Sure, wont happen today tho...
Maybe you have HDMI and DVI plugged in, maybe try unplugging the HDMI cord?
