[System Info Included] Load vender.dll fail. Install VGA Driver
So I wrote out everything in a word document and I guess I can't paste it in here or I am not sure how it works on this site. I just inserted pictures instead, my apologies.
1109753656_msg1.thumb.png.1cac83dc4bd9e8ecbe49560e96d8e4aa.png266040073_msg2.png.e7f7b106a55fddf81b705a3edabf261e.png1694361851_msg3.png.d004dc2cfd1ff8a6cd503f6cf149915d.png
Below are the reference pictures:
System Info
Geforce Drivers772417468_GeforceDrivers.thumb.png.b89e69d4e7f22395285234ede59120a8.png
Windows Version
Drivers
If anyone has any ideas on what else I should try I'm all ears.
Thank you for all of the future help,
Jest_Crazy
Well, with Windows 10 constantly breaking (updating) and Nvidia drivers being launched with little testing, add up the uncommon config you got there and I'm not even surprised it fails or throws errors.
First thing, if it worked before, you can always restore your PC to a previous state (if available).
Secondly i'd rollback to an older driver version that you know worked before. (do a quick google to find out how to use DDU to uninstall drivers and do a clean install). Try several versions back, somewhere in early 400.xx drivers or even better a 39x.yy. Quick google which driver is recommended from back then, reddit has plenty info.
Lastly, try contacting support of the Sonnet enclosure, and ask for advice.
cheers.
Thanks for
cheers.
Thanks for the ideas. I will definitely try them when I get a chance and report back if they worked.
