Concerned about cooling an Intel 9940x
Go to solution Solved by schwellmo92,
If you don't overclock it will be fine.
Hello,
I am currently building a computer that will be using an Intel 9940x. This computer will see a lot of usage so I am having issues with cooling. I'd like it to not be super loud and I don't have the biggest budget. I got this processor as a hand me down from my friend so I can't go with something else. I don't have the budget for a big water cooling system sadly. I currently have a Corsair 115i pro and a Fractal design r6 black case. I am wondering if what I currently have will be good enough. Thank you all.
H115i will do. Or rahter, you cant get better for less noise without going custom.
Desktop benching:
You can OC a 9940x on an H115i, I've done an i9 7940x to 4.6, couldn't come further only because it was a crap chip and the voltage wouldn't be stable any higher than like 1.27
Primary PC:
No plans to overclock it. I really appreciate your help! I feel better now after getting some second opinions.
