Need recommendation for video recording
Hello,
Can you guys recommend me the cheapest option you can think of (second hand is probably better) for the following:
I will record 1080p input of 3 cameras connected directly to the laptop. I will use OBS so i assume dedicated graphics card is a must here for nvenc option.
Thanks ;)
Max budget? Location?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
I already said recommend me the cheapest option you can think of that will do the job. I am in the UK.
Think of it this way:
1. What is the minimum requirement as hardware to record input from 3 usb cameras through OBS in 1080p 30/60fps and add a bit on top if the device you are going to recommend is way too old.
2. Having or upgrading it to SSD is pretty much mandatory, so SATA 3 at least is a must.
3. Having at least 3 USB ports is a huge plus as well.
Now, for example, you can buy Lenovo Y500 for around 200£ used, with 650M and 3rd gen i5.
Is this overkill, is it not enough, do you know something much better for this price or you might be able to think of a "modern" laptop that does the job for cheap?
