Will my RTX graphic card work with LG Ultrafine 4K? Can anyone verify?
Raptor300
Hi
I have a Windows 10 PC with an RTX 2080 graphics card. I am wondering if the LG Ultrafine 4K will work if I connect it to the RTX 2080's USB-C port (Virtuallink)?
Thanks
14 minutes ago, Raptor300 said:
Hi
Thanks
Give it a go i’d Say. If not, use DisplayPort
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
Thanks for your answer. I plan on purchasing this monitor because I want a small 4k monitor. However I want to make sure it works so that I don't have to return it.
Is there anyone who can verify that the LG Ultrafine 4k works on Nvidia RTX cards through USB-C?
The USB-C on RTX cards is a virtual link for VR. You can sort of use it for monitors but only with a USB-C to DVI-D or DisplayPort adapter and it does not work well. Use Display Port or HDMI, USB-C on the RTX cards is not intended for connecting displays. Is there a specific reason you need to use USB-C, the monitor will come with a Display Port cable as that is the intended connection, most newer monitors especially 4K use Display Port.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z690 Aorus Elite AX DDR4 | GPU - ASUS TUF Gaming OC RTX 4090 RAM - Corsair Vengeance Pro RGB 64GB 3600mhz | AIO - H150i Pro XT | PSU - Corsair RM1000X | Case - Phanteks P500A Digital - White | Storage - Samsung 970 Pro M.2 NVME SSD 512GB / Sabrent Rocket 1TB Nvme / Samsung 860 Evo Pro 500GB / Samsung 970 EVO Plus 2tb Nvme / Samsung 870 QVO 4TB  |
TV Streaming PC: Intel Nuc CPU - i7 8th Gen | RAM - 16GB DDR4 2666mhz | Storage - 256GB WD Black M.2 NVME SSD |
Phone: Samsung Galaxy Z Fold 4 - Phantom Black 512GB |
