How much slack is required for 6+2 pin cable?
Vynro
Alright, so I'm probably freaking out about absolutely nothing, or I'm not ? I have 2 seperate 6+2 pin cables that look like the first picture, and the "first" connector on them is hidden behind the cases grommets for wiring, though it's quite stiff because that first connector is actually stuck on the edges of the hole, and I'm worried if I leave it it could ruin the connector ? Though I do like the look of not having the extra cable
Pictures can deceive but I reckon if you can't make out any strain on the actual connector of your GPU (maybe you can check if you can feel the connector bending towards the cable), you should be fine.
WHIPLASH
CPU: Intel Core i7 6700k @4.7GHz
RAM: Corsair Vengeance RGB DDR4 2x8GB @3000MHz
MOBO: Asus ROG Maximus VIII Ranger
GPU: EVGA GTX 1080 FTW2
PSU: EVGA Supernova 650GS
CASE: Fractal Design Define S
Don't feel any strain...? Hopefully I'm good ? thank you !
Depends on the size of your tower.  A larger tower will expand more when heated and could pull the cable more taught.
I'm fucking with you... you're fine.
