Zotac RTX 2080 Twin Fan?
MathewH
I just purchased the Zotac RTX 2080 Twin Fan edition https://www.amazon.com/dp/B07K9SCJRK/ref=twister_B07NL2CG19?_encoding=UTF8&psc=1 for $700 (included $180 in free games)
In terms of power how does this specific card compare to some of the more expensive cards? Is there much of a difference?
SPECS:
CPU: i7 8700k @ 4.8ghz I GPU: ZOTAC RTX 2080 TWIN FAN EDITION I RAM: Corsair Vengeance Pro RGB 16gb 3200mhz I Cooler: Corsair h115i Platinum RGB I MOBO: Asus Prime z370-P I EVGA 750 WATT 80+ GOLD I SSD: Intel 500GB I HDD: Seagate 2TB I CASE: Darkflash Phantom MID-ATX Case
not much difference, gpu boost is rather temperature sensitive so you'll lose a little on the core clock, and if it's like my 2060 it'll have micron memory which tends to get lower overclocks than samsung memory. You'll likely be more affected by the silicon lottery than anything though
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Alright sounds good. As of now playing on a 1080p@240hz monitor so I shouldn't even have to overclock.
SPECS:
