Tips on how to achieve variable chamfer/beveled edges on <div> (SOLVED)
crispybagel
Hey guys, i've been looking around for a solution to this problem for a while now and i'm having a hard time getting it to work. What i want to achieve is a chamfer with variable radiuses on a div like this. Currently im using an image to get this result but i want text inside it so it would be much more viable if i had a div instead.
Appreciate all the help i can get!
Nvm i solved it using clip-path: polygon() like this.
div {
	height: 100px;
    width: 500px;
    background: black;
	clip path: polygon(
   		0 0, // x,y coordinate top left
    	100% 0, // x,y coordinate top right
    	95% 100%, // x,y coordinate bottom right
    	5% 100% // x,y coordinate bottom left
It creates 4 points and clips away everything outside of that.
