So my PSU just died and i need a replacement. For my budget, I found a few PSUs to choose from.
1) FSP Hyper K 500W 80+ ($65)
2) Silverstone Strider Essential 500W 80Plus ($64)
3) Coolermaster MWE 500W ($63)
4) Corsair CX Series™ Semi-Modular 80 PLUS 450w ($88)
5) COOLER MASTER MASTERWATT 550W SEMI-MODULAR 80+ BRONZE ($72)
6) CORSAIR VS Series VS450 (grey) 80 PLUS White Certified ($59)
7) EVGA 500 W2 500Watts 80 PLUS ($68)
8) COOLERMASTER MASTERWATT LITE 230V 500W 80+ ($72)
Updated with price, thank you guys!
https://linustechtips.com/topic/1046912-power-supply-choice-updated-with-price/
I'd say MWE... but those aren't very good options... all of them.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
What budget?
What country? (& what stores can you buy from?)
What system specs?
@House of Alex Look here for suggestions
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
13 minutes ago, Spotty said:
What budget?
What system specs?
Im from Singapore. Probably buying from local stores (or local websites). Budget wise i will say anything under 100 SGD is fine.
Thanks for the link! I looked at this just now but i am just wondering if anyone here have some really good (or bad) experience with the 3 power supplies i mentioned.
Spend the extra for the MasterWatt. That's all I can recommend.
Full Specs
Helios EVO (Main):
Delta - Laptop
Still need to know what hardware the system has in order to recommend a PSU.
Right i forgot.
Right now i have a 4th gen i5 and a gtx 760.
Looking forward to upgrade to a ryzen 5 and a 2060/1660ti in the near future.
Just now, House of Alex said:
Right i forgot.
The GTX 760 requires 2x PCIe connectors, I think?
That one.
