@Yokim It really depends on what fans you use. If you get something like Noiseblockers or Noctuas then the 140mm fans would be better/quieter. I would go for two 140mm fans because there will be more options in terms of looks.
Quote me to get a reply!
Well in terms of size 200mm is bigger than 2 140mm fans(20^2>14^2*2) but it really comes down to you, personally would take 200mm one because it will be more likely quieter...
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
Also for Watercooling later on... GL finding something to put a 200mm fan on :D
CPU: Intel i7 4790K @4.8GhZ  CPU Cooler: Be Quiet! Dark Rock Pro 2  Motherboard: Gigabyte Z97 UD3H  GPU: Asus ROG RX 480 8G OC Memory: 32GB Gskill Ares 2400Mhz  Storage: 2x Crucial M4 512GB SSD (raid0)  / 1TB Seagate FireCuda SSHD Case: Phanteks Enthoo Evolv ATX PSU: EVGA SuperNOVA P2 750W  Operating System: Windows 10 Enterprise LTSB (64 bit) Other: NZXT Hue+ LED Controller with 8 LED Strips for desk and PC lighting
Okey thanks guys!
I think I will go with 2 140mm.
Is it impossible to find radiatiors for 200mm? Are there any pressure optimized 200mm fans?
It's surely possible but definitely hard...
Okey thanks guys!
Larger sized fans are more directly for airflow and silence.
The bigger the fan, typically, the more CFM and lower RPM. The pressure is greatly reduced.
You probably won't find a 200mm diameter radiator.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
http://www.aquatuning.se/product_info.php/info/p12851_Phobya-Xtreme-400.html
Umm.. found one.
Just be prepared to do some modding with 200MM rads, only a few cases fit them well and easily. Do your research and save yourself the hassle I had with a 200MM rad.
One additional point is that if you go with a "standard" rad size you will be able to use it from build to build, case to case.
Anyhoo, the Bitfenix Specter 200MM fans fit the 200MM Phobya extreme well.
9900K  / Noctua NH-D15S / Z390 Aorus Master / 32GB DDR4 Vengeance Pro 3200Mhz / eVGA 2080 Ti Black Ed / Morpheus II Core / Meshify C / LG 27UK650-W / PS4 Pro / XBox One X
Two 140 especially because there are almost no good 200mm fans that ive found
Wha...psh...where do you find these things?!
In all honesty, I don't know how well the radiator will perform with one of the "suggested" fans being a Cooler Master MegaFlow 200mm. Looking at Cooler Master's site, the MegaFlow is rated as
  • 700 RPM
  • 110CFM
  • 0.595 mm H20
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
