USB to Ethernet Adapter
Christianm
I have a Dell laptop which does not have an Ethernet port and I also have an Asus old laptop with Ethernet port. I have a cable internet and I only have 1mbps connection (enough for me), my ISP have a local server (portal) where they have all types of files for their users, when we download something from their server we get 5 to 10 MBps (megabyte) through cable connected to laptop, portal is not accessible via wifi which I'm using right now.
so I just bought a cheap usb 2.0 to Ethernet adapter but I only get 600-700 kbps and because of that I have to use my Asus laptop to download files from server. I wonder if I buy USB 3.0 adapter (link below) will I get 5 to 10 MBps or it's just the same as usb 2.0? thanks
https://www.aliexpress.com/item/Ugreen-USB-Ethernet-10-100-1000-Mbps-Rj45-Gigabit-Network-Card-Lan-Adapter-For-Mac-OS/32400737540.html?spm=2114.10010108.1000014.3.51be61caVM4t4H&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.13338.128418.0&scm_id=1007.13338.128418.0&scm-url=1007.13338.128418.0&pvid=f4013cdf-68c5-403d-b3b6-c9fab1288f8a
https://www.aliexpress.com/item/USB-3-0-To-Gigabit-Ethernet-RJ45-LAN-10-100-1000-Mbps-Network-Adapter-For-PC/32919948573.html?spm=2114.search0104.3.20.43007027bxQ75O&ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_319_10059_10884_317_10887_10696_321_322_10084_453_10083_454_10103_10618_10307_537_536_10902,searchweb201603_16,ppcSwitch_0&algo_expid=9e95d205-9212-48c4-b025-453bc9d0e503-2&algo_pvid=9e95d205-9212-48c4-b025-453bc9d0e503&transAbTest=ae803_5
you should notice higher speeds with the adapter, worth a shot!
Ugreen is a pretty decent brand, it should work well.
As long as your laptop has a usb 3 port to plug it into you'll see an improvement, if your laptop only has usb 2 ports then a usb 3 adapter will give you identical results to the usb 2 one
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
adding on to others.
double checking your are not confusing, "bytes" vs "bits" per second.
bytes = 8 bits
bits = 1 bits
are you getting bits & bytes mixed up? 5Mbps = 600KB/s - 5MBps = 5MB/s (40Mbit)
If its 5-10Mbps then you're at the bottom end of that range, but within range...
USB2.0 theoretically has more than enough bandwidth to max out 10Mbps
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | EVGA GTX1070 FTW | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO | 12 x 8TB HGST Ultrastar He10 (WD Whitelabel) | 500GB Aorus Gen4 NVMe | 2 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
thank you everyone for replies. yes my laptop have two usb 3.0 and one usb 2.0.
I have upload two images for clarification.
Image 1: downloading file with this cheap usb 2.0 adapter with my Dell laptop.
Image 2: downloading the same file with my Asus laptop, LAN cable connected directly to laptop Ethernet port.
thanks
