My Denon 4300H is not showing L/R Bypass as Audyssey sound option
Profoundsoup
For some reason my receiver isn't giving me the option to use L/R Bypass with the Audyssey calibration. It only gives me the option for "Off" "Flat" or "Reference". Im not sure why this is. Id love to have just my subs EQ'ed but not my towers for music but its not showing me the option. Am i doing something wrong?
It likely won't show in a 2.1 setup. An alternative; Denon has a $20 smartphone MultEQ app that will let you disable the filter for the front speakers, under menu 'MultEQ Filter Frequency Range' you can disable the filter by dragging the bar to the left.
