Hey,
Attempting to mirror a display out to 3 monitors, have some digital signage that needs to be mirrored out from a pc onto 3 monitors.
Currently I'm only able to mirror onto 2 monitors and then the 3rd is extended, as far as I understand this is a limitation of windows.
Wondering if there is any product or even software that can take a single input and mirror it out to two displays through hardware preferably.
Edit: Should also mention that this is a Nvidia Quadro p5000 running display ports for each output
https://linustechtips.com/topic/1044277-mirror-a-pc-display-to-3-monitors/
Most of the ones I've seen aren't actually splitting the connection, windows still recognizes them as two separate monitors and therefore im unable to mirror on all 3.
If you can link a product that's capable of it would be greatly appreciated.
