Download speed is slower than Upload
1 hour ago, Fesoj said:Hey all, I recently picked up a cheap Gigabit PCIe LAN card to try and reach my connections full potential but its not quite there yet.
I was wondering if there were any typical causes of slow speeds caused by a PC's Network settings other than the classic "people in your neighborhood are all online doing stuff" kind of deal.
The ethernet port(intel I218-V Gigabit LAN) on my motherboard had a driver update and i saw a change from like 300down to around 500down. After installing the PCIe card i am seeing numbers in the range of 700down. Pics related.
Run the test again with your task manager open, see if you are hitting 100% CPU while performing the download portion of the test. This will skew your result and make it look worse than it is. 1G on SpeedTest.Net is quite CPU intensive due to them creating a large number of threads for download using TCP port 8080.
