2 weeks of troubleshooting and nothing
Pogbaku69
So as the title says I've been troubleshooting my PC for about 2 weeks now and honestly I've gotten nowhere.
I've built my PC over the years with mainly new and some second hand parts,my current configuration is :
Intel Xeon E3 1230 v3 - bought used and has worked perfectly for a year now, getting 715-720 CB score which is in line with what other users are getting. Max temperatures in games are at 63-65C. Cooled by an LC-CC95 (budget cooler but still keeps the temps low). MSI afterburner shows it running in games between 3.5-3.7 GHz as that is its max boost clock.
MSI H81M-P33- bought new and used it with 2 different processors, i3 4170 and this Xeon. Newest BIOS and CMOS cleared.
RAM: 2x 4GB DDR3 GEIL Dragon 1600MHz - bought new and used with 2 different CPUs,RAM is reported as running in dual channel and at 1600 MHz.
GPU: Had an R9 270 before. Bought a used ,under warranty miner card - RX 580 4GB Sapphire Nitro+. It is running the default BIOS and a slight overclock of 3% on Core,0% on memory. Core 1380/Memory 1750. +20% Power limit,radeon chill off,zero rpm off,custom fan curve never goes above 58C in games. Both power connectors (6 pin and 6+2 are plugged in firmly,triple checked). GPU never had issues of black screening,artifacts, driver crashes or anything like that. But it is creating me some problems.
Power supply: CoolerMaster B500 v2. Single +12V rail at 38A, 80 rated, bought new 2 years ago. Has 2x 6+2 connectors.
So in certain synthetic benchmarks such as Unigine Superposition and Unigine Heaven, the GPU shows as running at maximum clock (1380/1750), 100% usage and I get scores which are about the same as others (2526 Superposition 1080p extreme,1330 Heaven maxed out 1080p).
My monitor is an old 19'' screen which I have connected to my GPU using a VGA-HDMI adapter.  Its resolution is 1280x1024.
In games, the GPU usage is reported as being all over the place. Fluctuating between 0-5-20-100% all the time.One second it is at 100%,next at 5% , the clocks remain constant. and at their max (1380/1750).
When I force a resolution ingame to lets say 1920x1080, the GPU usage doesnt fluctuate as much but it still shows in MSI afterburner as dipping from 100% to 5% and clocks keep remaining constant (1380/1750). In R6 Siege,Overwatch its the same story on my native resolution. In some games like AC Origins, Watch Dogs 2, Wildlands I get lower FPS ingame than on videos on youtube of people running comparable setups (RX 580 and either a Haswell i5/i7 NOT overclocked, Skylake i5 etc). Watch Dogs 2 I would say runs the same or sometimes worse than it did on my old card. The GPU usage is really low like fluctuating between 5 and 50. On AC Origins benchmark I get lower results than people running RX 580 and Ryzen 5/i5 4460 at 1080p! Metro Exodus however runs at 80-100FPS on my card, Forza Horizon 4 runs maxed out at 80-100FPS... Certain games just refuse to utilize GPU and I get lower framerates than I should be getting. PUBG runs at 100FPS but even there my GPU is not utilized more than 50% no matter what resolution or details I select.
In games the card rarely draws over 120W which I think is suspicious a bit.
I've tried so far:
Opening furmark and seeing what the GPU powerdraw is, the GPU in furmark stress test draws 180-190W and runs it for hours without crashing or overheating. I think its not a problem with power delivery.
Reseating GPU , uninstalling drivers with DDU & safe mode, running both beta and stable drivers. Even tried running older drivers.
Reseating power cables.
Flashing default BIOS to card just in case.
Reinstalling Windows 10 & 8.1.
Disabling/enabling HPET.
I am honestly lost as to why some games work fine and I get great framerates while others run worse than on weaker/equal hardware.
Is it running with less PCIe bus bandwidth? You can check that with GPU-Z and some 3D apps running, it should be PCIe 2.0 x16.
software power readings only measures the GPU core's consumption and nothing else, the actual power draw of the card is 30-50w higher.
that's why they call it a power virus, the entire card is pulling more like 210-230w.
Desktop benching:
It is running at PCIe 2.0 x16. I checked with GPU-Z.
I didn't know about the actual core draw but I think it should still be enough power from the PSU.
In Wildlands and AC games their memory usage can be quite high, check if they are nearing the limits. This doesnt explain R6S and Overwatch though
Desktop benching:
@Pogbaku69 lower resolution is extremely cpu bound. Not to mention your mobo has non existent vrm without any safety features. My guess would be cpu is throttling in games therefore you can see gpu using jumping up and down.Before upgrade r9 was bottleneck,however with rx580 cpu get much higher CPU usage and I would guess it doesn't get enough power.
My PC --- CPU: Ryzen 7 3700x @ 4.3 || MoBo: Asus strix x470-F || RAM:32GB@3400mhz  4x8GB Corsair vegeance pro RGB || Cooler: Corsair H150i Pro AIO || GPU: Sapphire Rx5700 XT nitro+ || PSU: Corsair rm750i || Case: Thermaltake TG 31 RGB || SSD: 1x hp ex900 nvme 500gb 3x crusial mm500 1tb || Corsair M65 elite & Corsair platinum K95 || 2x Acer ed323 qura 1440p@144hz + Samsung c27fg70 1080@144hz.tb
@Jurrunio My RAM usage in AC and Wildlands is total about 6.5-7GB.
@Xcoool I'm finding it extremely difficult to think that the Xeon e3 1230 which is the same CPU as i7 4770 - the iGPU can be bottlenecking my RX 580. Its a 4C/8T Haswell. My CPU doesn't get throttled if thats what you meant to say, the temperatures never go above 65C and in Afterburner overlay the CPU speed stays at 3500-3600MHz. What is something that I can do to alleviate the CPU being a bottleneck at this resolution? Limiting FPS with RTSS or ingame? Honestly when I switch games to 1080p there is no noticeable difference in overall CPU usage. The GPU does stay a bit more at 100% but it does still drop,just not as much.
Have you tried checking the storage drives? Crystaldiskinfo for example.
Also check for disk fragmentation.
Desktop benching:
2 hours ago, Pogbaku69 said:
tl;dr
1
Have you turned on "Unified GPU usage monitoring" in MSI Afterburner general settings? I guess not, but you should - it will show you the true GPU usage values.
Also, you should upgrade your monitor. In some games, forcing a higher resolution simply doesn't work (although it might show as if it does) and there most certainly are issues scaling the resolutions. Just replace the monitor and your issues will go away. Try with a monitor from a friend or a relative if you don't believe.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
I've used that software and did a disk defrag, the hard drive is 2 years old. Nothing shows up that would raise red flags.
I have tried ticking that box but then the reported GPU usage stays at 0% despite me playing games. Wattman shows the same in its monitoring tool,the GPU usage fluctuates a lot. I will try hooking it up to my friends 1080p monitor to see what the GPU usage is like then.
