RTX 2070 not boosting over 1140MHz
In games like league the RTX 2070 will stay at 1140MHz and only give me 120 fps. Now a week a go i got like 300 fps and the clock speed was correct.
I do have a 60hz screen and a 144hz zcreen, so there might be a problem there, iv had that before. Please help.
You could have some kind of power saving feature enabled unknowingly.
"uhhhhhhhhhh yeah id go with the 2600 its a good value for the money"
how can i check that?
1. Frame rate limiter settings in games?
2. BIOS corrupted itself? Search "RTX 1350MHz". A BIOS flash fixes this on most of cases.
Desktop benching:
1. No lock in game, or in nvidia controll panel.
2. In heaven benchmark the gpu boost to 1940 no problem. so it isnt frozen. also, whenever i tab into league the clockspeed goes to 1410 for a few sec. (the base clock for my card).
1140mhz, seems to be some sort of multi monitor state.. idk
Dont want to flash the bios for warranty issues and so on.
  • 2 years later...
This problem is still ongoing even now in October of 2021.  This is a driver issue.  I mine a bunch of different Crypto currencies and I noticed when switching between the different applications I lose the ability to boost quite often.  It's in the switching of applications that causes the issue.  Installing the latest driver will bring back boost but never fixes the issue.  If I just run the same application I never lose boost.
The best and only way I found of resetting the driver and getting my boost back without a driver install or reboot was to use Nicehash Quick Miner.  Under the OC Boost (Opens Browser window on local port), there is an option to reset the Nvidia driver.  This resolves the issue much easier until they actually fix it!  Be about time don't you think Nvidia!
After posting, I decided to see if there was an easier option...
There is a 'secret' Windows key combination to reset the graphics driver! :)
Putting this information out there because I couldn't find a fast resolution after searching for a while.
How do I reset my graphics driver Windows 10?
To restart your graphics drivers, press Win+Ctrl+Shift+B on your keyboard. Your screen will go black for a split second and you'll hear a beep. Everything will then reappear just as it was before you pressed the hotkey. All your current applications remain open, and you won't lose any work.
There is a 'secret' Windows key combination to reset the graphics driver! 🙂
Turns out this doesn't solve the issue.  Only quick method is to use NiceHash Quick miner OCTUNE
