Funky 1070 power connections?
OtterlyDumb
I recently got an EVGA GTX 1070, but have had issues connecting the power connections to it. I don't seem the have any single connector that fills in all 8 spaces, is there a combination of different things to connect it? Also, is there RGB anywhere? I heard that there is, but I don't know how to control it if it is on the card.
what PSU is this? That connector is called the PCIe 8pin connector, many PSUs give you a 6+2 plug which works like a 6pin if you leave out the 2, like an 8pin when you include the 2.
Desktop benching:
see this topic
and if there is RGB on the card, you can control it with the supplied software
Main PC:
CPU: AMD Ryzen 5 5600X | RAM:Corsair LPX 3200 mhz (16Gb)
Mobo:ASUS Strix B550-F Wifi | GPU: MSI RTX 2070 Gaming Z
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Be Quiet straight Power 10 500 watt
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Samsung 8 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Galaxy A50
With regards to the RGB question, there are no physical controls, you will need to control the LEDs by installing EVGA's Precision X1 software.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
I think I found it, but it doesn't go in all the way because of some plastic parts on one side
try rotating the connector (and also the extra 2pin part) around? or just check the PSU's page on whether it has a PCIe plug. Note that the EPS plug for the CPU looks identical (comes in either 4 or 8pin variant) and they are not compatible. Do not use the wrong one.
Desktop benching:
It is the right way. Also, might be a little late to mention this, but it looks like someone dremel tooled the thing into 2 pieces, is that normal?
dremel tooled
I dont get this.
Desktop benching:
I dont get this.
It looks like it wasn't made to look like the way it is
just to clarify, I don't see what you're seeing.
Desktop benching:
It looks like a normal 8 thing but someone sawed off two of the things
don't use it if you're not sure. Sounds like someone trying to mod a EPS 8pin to PCIe 6pin
Desktop benching:
Well, I think I'm out of luck for now, can you point me towards an adapter for this?
I can't, without knowing if the PSU is even worth investing an adapter
Desktop benching:
I think it is an H1000e?
You'll want to look at it and be sure of whatever it is before any suggestions will be applicable...
HEDT: i9 10980XE @ 4.9 gHz, 64GB @ 3600mHz CL14 G.Skill Trident-Z DDR4, 2x Nvidia Titan RTX NVLink SLI, Corsair AX1600i, Samsung 960 Pro 2TB OS/apps, Samsung 850 EVO 4TB media, LG 38GL950G-B monitor, Drop CTRL keyboard, Decus Respec mouse
Laptop: Razer Blade Pro 2019 9750H model, 32GB @ 3200mHz CL18 G.Skill Ripjaws DDR4, 2x Samsung 960 Pro 1TB RAID0, repasted with Thermal Grizzly Kryonaut
Gaming Rig: i9 9900ks @ 5.2ghz, 32GB @ 4000mHz CL17 G.Skill Trident-Z DDR4, EVGA RTX 2080 Ti Kingpin, Corsair HX1200, Samsung 970 EVO Plus 2TB, Asus PG348Q monitor, Corsair K70 LUX RGB keyboard, Corsair Ironclaw mouse
HTPC: i7 7700 (delidded + LM), 16GB @ 2666mHz CL15 Corsair Vengeance LPX DDR4, MSI Geforce GTX 1070 Gaming X, Corsair SFX 600, Samsung 850 Pro 512gb, Samsung Q55R TV, Filco Majestouch Convertible 2 TKL keyboard, Logitech G403 wireless mouse
this unit has 4 PCIe 6pin right? You can use a 2x 6pin to 1x 8pin adapter then
Desktop benching:
